Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 02-02-2004, 12:46
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Can this be turned on a lathe?
Originally Posted by sanddrag
Well, the gear is a steel Martin gear. As for it being hardened, I have no idea. All I know is that it was not too hard to drill.
If the gear is hardened, it will probably only be locally flame hardened in the area of the teeth. Since you appear not to be messing with the teeth it shouldn't be a problem.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 02-02-2004, 19:10
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Yes its easy to machine in a lathe, use a collet to hold the part by the gear side. No the collet wont hurt the gear teeth. you should be able to machine it, doens't look like it has been harden. As for the cutting tool hitting the gaps, dont worry about it, just go slow with your feed, the speed the cutting tool moves at. You could probably get away with an rpm of 100 or a little more. Thats what i would do. Any questions or complication just ask.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
For those of you who turned off MNF and went to bed.... D.J. Fluck Chit-Chat 11 08-10-2003 23:30
Who turned in their chairmans at UCF? ComBBAT_Amy Chairman's Award 2 18-03-2003 20:27
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
cutting wheels archiver 2001 3 23-06-2002 23:52
Location, location, location... archiver 1999 10 23-06-2002 23:02
