Go to Post Please Note: Elgin is still wearing his safety glasses. Practice safe Dewing. - JohnBoucher [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 21-02-2002, 14:17
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
All i've got to say is if you grab 3 goals you better have one heck of a drive train, because i know i would go after you.
Remember, any team can push goals, dosn't matter if they are ball getters.
Incase you haven't figured it out, i think that the extra weight of that thrid goal gripper would be better spent elsewhere- 1 is good, 2 is great, 3 is overkill.
Probably wrong,
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 21-02-2002, 14:18
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
There are a lot of factors that will determine which robots will be king.
yes there are lots of fators but only one that will do well
If your robot is the strongest and can move goals at will that is the robot that will win.
If there is a good ball handler what can he do if he doen't have a goal to put them in.
after playing the game at Quincy MA . It prove that having a strong robot will and can score big points.
The only way you won't score big point if the other team trys not to get points. That happen once. at that time both robots went into the other team end zone to score 20 point which x3 = 60.
so having two strong robots. you can do almost anything you wish to do.
Unread 21-02-2002, 15:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
It sounds so simple when you say it...
... but I believe that it will be more complex when the dust settles.
The central question as far as I can noodle it out in advance is this:
Can two of the BEST goal handlers get 3 goals tied up before ANYOTHER robot can effectly get one and keep it out to of the hands of the other two?
If the answer is yes, then this game boils down to nothing but a shoving match of the best pushers out there with balls being a total non-factor.
If the answer is no, then balls spell the doom of the pushers.
I don't believe this is a simple question. One day I am sure the pushers will rule the day. The next I am sure that ball handling is key.
As I say... ...time will tell...
Joe J.
Unread 21-02-2002, 16:04
FRC #0061
Rookie Year: 1995
it is not to hard to get the goals. there is no place to hide.
the best part is the goal are so big it is very easy to grab them.
in one of the matches a team brought there goal to the there side to throw balls in. they put all ten balls in. but the problem was we had one goal and we use this goal to block them from ever coming out of there end zone. so we ended up get the point for the ten balls. this is only one way of playing the game
once again if you have the strong robot your chance of placing the point is much greater then one that does not have power.
rember it take time to pick up balls the time you are picking up ball the strong robot are taking the goals.
I hope we get pair up with good ball handler for the seeding round. you can get alot more point. with the help of your teammate.
but you can win every match by sure power.
Unread 21-02-2002, 17:07
emilywll emilywll is offline
#0191 (X-CATS)
emilywll is an unknown quantity at this point
Send a message via AIM to emilywll
our bot does both
I think that a versitile team will have an advantage in this game. Our team can acquire two goals and acquire, store, and shoot balls.
I hope life isn't a big joke, because I don't get it
Unread 21-02-2002, 19:25
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Re: ball getters
Originally posted by Chris Hibner
This is not true. 3 goals in the goal scoring zone is 30 points and is impossible to beat since without any goals, the most a team can score is 20 pts for their two robots in the end zone.
That would be stupid. If the other teams realize that they can't win without any goals, all that they would have to do was make sure to stay out of their own end zone and the "winning" team would recieve ZERO qualification points
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 21-02-2002, 19:48
FRC #0061
Rookie Year: 1995
This has been tried. to stop that you can simply put your robots into there end zone for 20 points
20 x 3 =60 points
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
I think that a fast single-goal grabber will be useful in any round. It will deny those 3-goal robots the third goal, and maybe the second one. And what good is a ball loader if it cant get hold a of a goal?
Unread 21-02-2002, 20:35
Of course 0 points for you means 0 points for them. They still get 20 points if they end with 20, they would have to have a good reason for doing that too you.
Greg
Unread 21-02-2002, 21:04
Alfred Thompson's Avatar
Alfred Thompson Alfred Thompson is offline
Adult troublemaker
FRC #0811
Alfred Thompson has a spectacular aura aboutAlfred Thompson has a spectacular aura about
Send a message via AIM to Alfred Thompson
SO you have a three goal grabber. Can you grab all three before the other team can get even one? Probably not. So the other side grabs one goal, puts 20-40 balls in it. Then your goal grabber, pulling the two goals it already has, is going to catch and out pull the other robot? Frankly, I don't think so.
Unread 21-02-2002, 22:56
ReijiH's Avatar
ReijiH ReijiH is offline
#0115 (Monta Vista Robotics Team)
ReijiH is an unknown quantity at this point
Send a message via AIM to ReijiH
Even if one robot managed to get three goals really quickly early in the game.....question is, would it be able to hold on to it for the rest of nearly 2min that'd be left of the match?
Think medical technology's perfect? Well Think again
"March 4th, 2002: A man walked into his Doctors office in Sacremento, California. He told the Doctor, "Doc, it hurts when I go like this!" The Doctor said "Well, don't do that!" The man later died of cancer."
Unread 22-02-2002, 02:08
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally posted by ReijiH
btw, two lefts does not make a right
Right, but three do!
Unread 22-02-2002, 09:49
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
Re: Re: Re: ball getters
If my team left our home zone to spite the winning alliance, we'd only be hurting ourselves. Not only would we also end up with zero qualifying points, but I'm certain that if either of our opponents were in a position to pick an alliance partner, they'd think more than twice before picking up my team.
Unread 22-02-2002, 12:27
FRC #0061
Rookie Year: 1995
if the other team puts 40 balls into the other goal we would drop what we have and take that goal.
What a concept, another team works hard to get more point for you to take away.
Unread 22-02-2002, 12:51
AKA: Dr. Joe
FRC #0088 (TJ2)
I disagree
I disagree.
The rules of the game are clear. In the elimination rounds, it is winner take all, but in the seeding rounds, the name of the game is maximize seeding points.
I think it is perfectly okay for a alliance to score zero in an effort to make the other alliance give up a goal.
To me, it is all part of the game.
Similarly, a team that builds a killer seeding round robot and then picks the best elimination round robots to win a regional has just as much claim to the title as the two robots that won all the matches in the elims.
Again, the rules are clear. We are all trying to maximize our chances of winning a tourney while staying within the rules.
I'm good with it anyway...
Joe J.
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
What was with the ball? purplehaze357 Championship Event 4 30-04-2002 23:15
ksc - ball bots ohm my katie86 Regional Competitions 8 10-03-2002 22:52
