Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 02-02-2004, 12:13
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
eNc is an unknown quantity at this point
Send a message via MSN to eNc
Ignition Animation
Hey guys, Who did the ignition animation? Can you please tell me how you achieved the electricity flowing around the antanna of the control board at the begining of the animation. And for the text did you do it in flash and just inserted it into the animation with video software editor ?
Unread 02-02-2004, 14:06
reisser's Avatar
reisser reisser is offline
Ph.D. User
AKA: Brandon Reiss
#0103 (Cybersonics Technology Team)
Team Role: Animator
reisser is on a distinguished road
Send a message via AIM to reisser
Re: Ignition Animation
The electricity at the beginning of ignition was achieved using a sphere following a spline. A video post glow effect using the "electricity" style was applied. If you are familiar with the video post, then it should be fairly simple. It is just a matter of tweaking motion and such.
All text effects were produced in 3ds max 4.3 as well. That is animated text using leading and scale. There are lens flares and glows in the video post that control the lighting effects you see. Basically, all of the effects in that piece are achieved in the video post.
Let me know if you have any additional questions.
-Brandon
Doctor?
Unread 02-02-2004, 16:30
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
-Brandon
This is kinda dumb but how do you make custom textures, eveytime i try to drop it onto the object it won't go on it.
Unread 02-02-2004, 16:34
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
uhh how did u get the text only... its really confusing to me.
Unread 02-02-2004, 17:42
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
what do u mean the texture wont go onto the object?
Explain in detail please.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 02-02-2004, 18:48
PhatalEphekt PhatalEphekt is offline
#0935 (RaileRobotics)
PhatalEphekt is on a distinguished road
I think s/he meant that the custom image file won't drop onto the object, I've had this problem before. Just pick a blank material and go down to the maps rolldown, then drop your image onto the difuse map and make it 100%
Now you're ready to drop the material onto the object
[edited for grammar and logic]
Unread 02-02-2004, 19:04
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
Text only...
The process was one of looking at font after font on the web. When we finally found one we liked, we downloaded it and installed it to windows by adding it to the font folder. We also added it to the font folder in the MAX directory.
Using a text spline in MAX, we extruded the words we wanted for the animation.
I am not really sure what you are asking so I am trying this response. Please clarify.
-Brandon
Doctor?
Unread 02-02-2004, 20:13
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
Text only...
-Brandon
i mean like how did you get the text to show up on the screen by itself? was it located at different co-ordinates in the max file and then u just renderd a camera onto it, then edited it in the video ? and how did u make that lightning effect over it... Thanks for all your help.
Unread 02-02-2004, 20:38
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
oh ok ima c if this works ty... (i'm 'he' lol)
Unread 02-02-2004, 20:56
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
You guys had a great animation last year... everything was good in it. I'm also curious as to how you made your text "appear" in max, there's some effect applied to it that makes it look like something flies by and then Voila! awesome looking text.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 02-02-2004, 20:59
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
The text shows up by itself because it is the only item in the scene. Actually, I rigged up black planes to move past each other and reveal the text. Linked also to the leading edge of the planes was a light. On that light I placed a lens flare effect. That is the leading effect you see. The text is just the extruded spline i mentioned earlier. Lastly, the electric "fizz" left on the letters is just a lens effect glow in the video post that is set to electric style.
Is that what you were wondering?
-Brandon
Attached is the original scene file. They all are done in the same fashion.
Doctor?
Unread 02-02-2004, 22:05
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
-Brandon
Did you do all the words in different scenes and then put them in sequence with video editing software... and btw what at those blue things at the end of each of the slides, like what type of object are they ?
Unread 02-02-2004, 22:44
reisser's Avatar
Ph.D. User
AKA: Brandon Reiss
Team Role: Animator
Haha...
I laugh because the blue things are named "schwing01" and such.
Those are just twisted and skewed chamfer boxes. You can see that in the heirarchy of modifiers if you look in the modify panel.
The word scenes are spearate. We render to frames and then compile in Adobe Premiere. Premiere is a hot piece of software. You should pick up a copy. It is very easy to use.
-Good luck.
Doctor?
Unread 03-02-2004, 09:05
I agree, Premiere is hot
Thanks for posting that on there, I'll take a look at it tonight and post any other questions I have.
Again, your animation was awesome last year.
Unread 03-02-2004, 19:00
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
-Brandon
When i try to render with video post its looking for breakthrough.tga, which isn't in the zip, so ya might want to add that to get the full effect, as now all I see is some lense flairs.
Where has all the fun gone?
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
award for regionals Tyler Olds 3D Animation and Competition 13 20-12-2002 18:16
1999 Animation award archiver 1999 11 23-06-2002 23:08
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
the animation teams of F.I.R.S.T. animation teams are under appreiciated! Zeinin 3D Animation and Competition 11 14-01-2002 10:36
