EDU won't power up.
Just started fooling around with our EDU bot.
I plug in a 7.2v battery and at that instant the Battery Power and fault status light emit a quick red flash. Hit the power button... no go. Any ideas? or should I just call innovation first. -Nick |
Re: EDU won't power up.
Recharge the battery / Check the battery voltage
How long did you hold the power on button? You need to hold it down for a second or so to get it to start up...
You fried the on switch on the eduRobot by hooking up a power supply or something.
Solution: Hold power button on and then as you are holding it plug in the battery. Quick fix. We did it too. :-) Thanks, Ryan Waliany |
Check that there are no shorts from 7.2 or 5 v to gnd on any ports or IO. The internal current sensor shuts off the EDU upon short detection. |
| power to the pits | Ken Leung | Off-Season Events | 12 | 11-05-2003 22:48 |
| is there eletrical power in the stands | Ben Mitchell | Championship Event | 14 | 26-02-2003 18:42 |
| URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! | kmcclary | Electrical | 8 | 10-10-2002 10:56 |
| power of globe motor with gear box? | Ken Leung | Motors | 5 | 21-11-2001 13:43 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
