#26
Re: Save time? Use aluminum extrusion kits!
You could try 80/20. They make 1"x1" 1"x2" 2"x2" and many other sizes. We used the 1"x1" last year and are using it again this year, and have found it to be strong enough for our needs. It is actually lighter than comparably sized aluminum tube, until you add the fasteners. This year we welded the frame and saved nearly 20 lbs from not using fasteners. T-nuts and fasteners do add up, both in weight and cost, however.
Cory |
| Actual execution time measurement | Dan | Technical Discussion | 5 | 24-03-2003 11:36 |
| Solution to Timing Loops | Steven Carmain | Programming | 39 | 10-02-2003 13:33 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
| Definition of aluminum extrusion...? | kangarue23 | Technical Discussion | 4 | 25-01-2002 16:53 |
| precision grade aluminum extrusion - item MB Kit | Loren 930 | Technical Discussion | 2 | 11-01-2002 21:42 |
