Go to Post When I got home from work my facebook wall had exploded with people chanting the names of dead scientists. Did someone say culture change? :cool: - Ian Curtis [more]
  #31   Spotlight this post!
Unread 02-02-2004, 02:19
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Re: Save time? Use aluminum extrusion kits!
im wondering if Item or anyother company sells extrusions. also are the 20/20 profiles for Bosch rexroth and ITEM the same? can i use bosch with item fasterners and back. Bosch rexroth fasteners are really expensive, t-nuts $.75 a piece and blocks $1.50. Im wondering how much is item and will it work with Bosch and if i can buy without the package. Other companies would work too. Does anyone have any experiance with the inch series?
info would be great!
Thanks!
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
  #32   Spotlight this post!
Unread 02-02-2004, 18:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You could try 80/20. They make 1"x1" 1"x2" 2"x2" and many other sizes. We used the 1"x1" last year and are using it again this year, and have found it to be strong enough for our needs. It is actually lighter than comparably sized aluminum tube, until you add the fasteners. This year we welded the frame and saved nearly 20 lbs from not using fasteners. T-nuts and fasteners do add up, both in weight and cost, however.
Cory
2001-2004: Team 100
2006-Present: Team 254
  #33   Spotlight this post!
Unread 02-02-2004, 19:35
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Cory
Yea well our school is not allowing us to use our welder so we cannot use the weld material. So need to get bosch and i want to find out where i can get the fasteners for cheaper. thanks
AmX
  #34   Spotlight this post!
Unread 02-02-2004, 19:53
Mike M. Mike M. is offline
insert custom title here
Mike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant future
Cory
not to mention t-nuts can be almost as big of a pain as set screws
Gael Force 126 2003-2004 Mechanical, Pit Crew, Grady's #2
T-Hawks 1100 2005-2007 Mechanical, Driver, Coach
Rhodewarriors 121 2007 IRI Operator
PiraTech 2023 2008 Mechanical, Coach
Gael Force 126 2009-2010 Mechanical, Photographer
Current [RIDE] Volunteer Coordinator
  #35   Spotlight this post!
Unread 02-02-2004, 20:02
Cory's Avatar
AKA: Cory McBride
Well, seeing as this is a thread about aluminum extrusion, theyre kind of inevitable. They dont come loose all that often if you use them properly. We never really had trouble over two competitions, although they do need to be tightened periodically.
Cory
2001-2004: Team 100
  #36   Spotlight this post!
Unread 02-02-2004, 20:53
any time we can we try to eliminate t-nuts by just drilling and tapping to eliminate the t-nuts
  #37   Spotlight this post!
Unread 03-02-2004, 10:38
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We eliminated T-nuts by using 1/4-20 square nuts and 1/4-20 x 1/2" button head cap screws. These work extremely well and are quite inexpensive compared to the metric t-nuts.
If you tighten them with a long-handled allen wrench or a 3/8" drive allen head socket then they will not come loose in competition. The hardened cap screws are very tough. None have broken in 2 years of competition.
The square nuts do not turn in the extruded channel, and can even be forced into the channel from the side if the end is blocked, just like T-nuts. We got them from MSC.
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
Definition of aluminum extrusion...? kangarue23 Technical Discussion 4 25-01-2002 16:53
precision grade aluminum extrusion - item MB Kit Loren 930 Technical Discussion 2 11-01-2002 21:42
