Go to Post ...after all these years Dean is still on message, and the message still resonates. - Richard Wallace [more]
Unread 02-02-2004, 20:29
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
using single solenoid like a double
We're wondering if it is possible to use a single solenoid like a double basically by having to only press a button once instead of holding it down. Tell me if I'm crazy about the solenoid thing, but it seems possible to edit the program so that pressing the thumb or trigger on a joytick (pX_sw_whatever) once will keep the relay attached to its corresponding relay output in forward mode. How would you go about doing this? I think I have an idea, but I am a n00b and don't wanna embarass myself....
Unread 02-02-2004, 20:42
Guest
Posts: n/a
Re: using single solenoid like a double
The double-solenoid valve works by outputting air into one side of the piston to make it extend. You then set it in reverse (the spike) to put air into the other side of the piston to make it retract. You can't model a double-solenoid using a single-solenoid by changing the software. The purpose of a double-solenoid valve is to be able to actuate the piston in both directions, ONE single solenoid valve cannot do this, but TWO SINGLE solenoid valves can
Last edited by SilverStar : 02-02-2004 at 21:15. Reason: misspelling and wrong words
Unread 02-02-2004, 20:50
Originally Posted by SilverStar
The double-solenoid valve works by outputting air into one side of the piston to make it extract. You then set it in reverse (the spike) to put air into the other side of the piston to make it extract. You can't model a double-solenoid using a single-solenoid by changing the software. The purpose of a double-solenoid valve is to be able to actuate the piston in both directions, ONE single solenoid valve cannot do this, but TWO SINGLE solenoid valves can
Ok so I am indeed crazy about the solenoid thing, but can anyone help me out with a way to keep the relay forward while only pressing the button once instead of holding it down?
Unread 02-02-2004, 21:14
Guest
Posts: n/a
Sure, the "toggle" code you need is at the repository:
http://nrg.chaosnet.org/repository/viewcode?id=23
Unread 02-02-2004, 21:15
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
if you mean you want to use two buttons like "on" and "off" buttons, here's one way to do it:
static char btn_status = 0;
if(p1_sw_aux1) btn_status = 1;
if(p1_sw_aux2) btn_status = 0;
relay1_fwd = btn_status;
basically, just declare a static variable (so that it holds its state), then use the input from the buttons to set the variable at the appropriate times. (note - some of the input variable names may be off, i'm doing this from memory only)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 02-02-2004, 21:17
Guest
Posts: n/a
The code needs to be made slightly more complex because, as I interpret it, SteveO wants one button to toggle, my code above solves that.
Unread 02-02-2004, 21:21
Computer Guy
AKA: Dav
either way you want to work it.
Unread 02-02-2004, 21:33
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Couldn't you do it with a simple XOR operation?
i.e.
relay1_fwd ^= p1_sw_trig;
Unread 02-02-2004, 21:38
Guest
Posts: n/a
No, because the p1_sw_trig will remain true for more than one frame (unless your driver moves faster than light ). Thus, relay1_fwd would continuously switch from 0 to 1.
Unread 02-02-2004, 21:57
#0246 (Overclocked)
Good point.
Unread 02-02-2004, 21:59
ahhh merci SilverStar, I was thinking of using something similar with even or odd number of times pressing the button, this works
Unread 02-02-2004, 22:10
#0246 (Overclocked)
If you do it this way, it should only toggle the relay output when the button transitions from one state to another. That should eliminate the problem of infinite toggling that was present in my last suggestion.
// declare this as a global variable
bool LastButtonValue=0;
// place the following within the main loop
if(p1_sw_trig!=LastButtonValue)
LastButtonValue = p1_sw_trig;
Unread 02-02-2004, 22:42
Guest
Posts: n/a
Angry Re: using single solenoid like a double
umm... that's exactly what's in the repository link above .....
Unread 02-02-2004, 22:49
#0246 (Overclocked)
It's a little more concise, but yeah, you're right. I shouldn't attempt to think when I haven't slept much - this is what happens. Sorry.
Unread 02-02-2004, 22:51
Computer Guy
AKA: Dav
nothing really to be sorry about - posting the code here doesn't hurt.
also, instead of a global variable, i'd recommend a static - that way, you don't have any possible variable conflicts.
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
double solenoid gail OCCRA 0 11-10-2002 19:42
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
