Go to Post I Don't like to think in the Box so i try not to make robots look like them. - Tytus Gerrish [more]
Unread 02-02-2004, 22:45
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 2004 chassis 930
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: pic: 2004 chassis 930
Good looking base. The extruded aluminum works incredibly well, as has been mentioned in previous threads. Good luck!
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 02-02-2004, 23:31
Umm Errr...
Why doesn't anybody use 8020? Everybody seems to use bosch, kanya. Item etc.
Btw it looks nice. Love how you interted bearings directly into the extrusion.
1139 Alumni
Unread 02-02-2004, 23:45
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Wow... very nice use of Item MB extrusions. This is simply elegant.
I have a couple of questions...
Is that mostly "5 series" extrusion, with 20 mm widths?
Do you use mostly m5 drop-in t-slot nuts?
How much does the assembly in that picture weigh?
Andy B.
Unread 03-02-2004, 00:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Rickertsen2
Why doesn't anybody use 8020? Everybody seems to use bosch, kanya etc.
We use 8020. We got a whole bunch of it for free last year from some guy who was clearing out a warehouse full of it. It works pretty nice, although it's *REALLY* heavy when you add up all the plates, bolts, and t-nuts. Our frame was 40 lbs or so before we took the plates off and welded it. Based on Inventor's weight calculations, it should be ~14-15lbs now, which makes it real nice
[edit] Andy, it looks like they drilled and tapped quite a bit of it
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2004, 09:54
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
We also use 8020 (-1010, 1" x 1") for our basic chassis. Problem is the weight, especially if you don't really need the strength. If the chassis pictured is close to the robot footprint limits (30 X 36) then I would conservatively estimate about 64 feet of extrusion used in this design. You are looking at approximately 32 pounds, and that is BEFORE any wheels, sprockets, chain, gears, motors, pneumatics, battery, ..., and any additional mechanisms to play the game. OUCH ... I don't think we could stand that.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 03-02-2004, 16:36
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
Ok, seeing as I posted the picture I guess it’s only fair that I answer some of your questions.
All extrusion in the picture, excluding the bearing blocks, are item profile 5 20x20. The bearing blocks are item profile 5 20x80.
The only t-nuts used are to hold the ‘belly pan’ to the bottom of the chassis. All the rest are what are called standard fasteners (see picture).
For the bearing blocks we tapped the ends of the extrusion and milled clearance holes for M5 screws that go through the 20x20. This eliminates the problem that we see many teams facing each year with their pillow blocks shifting around on them. This also allows us to easily remove the bearing blocks if repairs are needed by simply taking out the four screws that hold them in place.
We weighed everything you see in the picture above at just over 20 pounds.
Ryan Lowerr - Ryan@lowerr.com
Check out my LEGO creations here!
Unread 04-02-2004, 18:37
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Cory
I thought that you could not weld 80/20 because of the alloy its made from. We wanted to last year, but would teacher said we couldn't becasue of the alloy.
Unread 04-02-2004, 19:38
Cory's Avatar
AKA: Cory McBride
It is made of 6105 Aluminum. I think that is one of the tougher alloys to weld. I don't really know, since we had professional welders from the Stanford Linear Accelerator weld it.
Cory
2001-2004: Team 100
Unread 04-02-2004, 19:48
westfalia's Avatar
westfalia westfalia is offline
Custom User Title
AKA: Doug
FRC #2234
westfalia is on a distinguished road
Send a message via AIM to westfalia
I think the way it works with the 8020 and welding them is that as long as you take a grinder to the parts you want to weld, it will weld fine. It's just the anodization that messes the welds up. We use 8020 (this is our second year) and although it's heavy it makes it really great for new team members to get in on the action of building and repairing the robot, because it's so easy to put together. ...If only we could use extruded made out of titanium or carbon fiber! I know, i know...
~Doug
Former 341 team member... Now attending Drexel University and mentoring team 2234!
pic: Team 190 Chassis and Driveline CD47-Bot Robot Showcase 1 01-02-2004 01:57
2004 edu controller (PIC) is out! caffel General Forum 13 09-10-2003 23:02
pic: The Full 2004 RC?! CD47-Bot Extra Discussion 7 07-10-2003 17:19
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
