Go to Post What's the point of competing if you're not going to be competitive? - davepowers [more]
Unread 02-02-2004, 02:30
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Header rows on the R/C
Has anyone found a proper header or connecter to use with the input rows on the R/C. I havent had much time to check it out for myself and i would hate to use a bunch of cd-rom to sound card cables for their ends. I am going to try and measure the pins and check out NIO and the other electronics suppliers. If this has been covered in another thread or has been posted I would appreciate a link to it.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 02-02-2004, 02:57
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
Re: Header rows on the R/C
I can't say for sure, because I don't have the controller here with me, but unless they changed something, a standard PWM cable should fit it.
Bill
"Those who think that they know everything are especially annoying to those of us who do."
Unread 02-02-2004, 03:13
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Right now, we're using IDE cables salvaged from old computers. We just need to cover the signal pin for each 3pin set, so having two rows isn't a big deal. If we find something cheap that works better, though, we'll probably be quick to use it.
$5 each, from Innovation First, is pretty steep. Tower Hobbies' $8 isn't any better.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 02-02-2004, 07:27
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
3-conductor housings: jameco.com, part number 157382, $0.24
female crimp pins: jameco.com, part number 100765, $0.09
The documentation describes how to use them. I use the cheap crimper from Radio Shack. Buy 50% more crimps than you need because you will mess up a lot until you get the hang of it. A pack of three housings w/ 9 crimps from the local hobby shop costs $6.00.
Unread 02-02-2004, 21:12
Jeff Zampieron Jeff Zampieron is offline
#0073 (Visioneers)
Jeff Zampieron is on a distinguished road
Send a message via AIM to Jeff Zampieron
http://rocky.digikey.com/scripts/Pro...A9BAG-0308F-ND
I think these are a good thing for the headers, then you just extend.
when i get them i'll let you guys know.
Unread 03-02-2004, 02:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've been using some nifty AMP connectors that I found at Digi-key. The information can be found toward the bottom of the infrared beacon tracking FAQ.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-02-2004, 09:36
The big guy
your the man kevin, rep points to you
Justin Stiltner
KI4URQ
Unread 04-02-2004, 23:27
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Thread: "digital i/o connectors"
http://www.chiefdelphi.com/forums/sh...23&postcount=5
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Header Not Found (adc.h) NotQuiteFree Programming 2 23-01-2004 16:26
Needing A header file jweric Programming 19 23-01-2004 10:25
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
EDU R/C Based Robot Venkatesh Technical Discussion 2 02-12-2003 15:20
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
