Wheels - Plywood
What are the standings on plywood wheels???
The problem is that we do not know american regulations and stuff over here and they have to be certified or something. Please help us !!!! |
Re: Wheels - Plywood
i don't see anything in the rules that outlaws wooden wheels, but you might want to put some sort of soft "tire" around the outside of the wheel just to be on the safe side. |
There are no restrictions on what you make your wheels out of as long as they do not violate any other rule. The primary concern is not to damage the carpet.
-Mr. Van Coach, Team 599 Granada Hills Charter High School |
one input... if you make the wheels out of plywood make sure that its not easy for some other bot to hit your wheels easily...
::i dont think that a plywood wheel will survive when a really fast robot which is going about 12 ft. per sec. hits it:: edit- there are ways that you can make a good plywood wheels... so just make sure that you build it the right way... Last edited by Arefin Bari : 03-02-2004 at 20:13. |
What if metal touches the side of the 6 inch platform. Is that legal?
As a followup to Raul's comment, make sure they're study no matter if another robot can hit them or not. If a robot hits the side of your robot and your wheels are grippy and don't slip sideways, it'll still be damaging. And keep in mind that your robot is going to have to run your robot through atleast 6 rounds at a regional, possibly more. Design for the duration, or make a lot of spare wheels.
#7
Its not so much the problem of sturdiness , its just that there are many regulations in america about wood and stuff and we have to spend a ton of money to get a new crate built for our robot and then more money to get a certificate for it. We have used ply wood wheels in the past with good success, as we have a way of moulding rubber to it (dont ask me, all i know is that we can)
#8
tbh last years robot would work pretty well for this year , as it is a box stacker which worked well , i am sure i can dig some photos up sometime |
#9
Denman,
Plywood is fine for wheels, you obviously have overcome the the problems usually associated with these wheels and that is keeping them round and mounted securely. (You can't drive straight if your wheels keep leaving the ground.) Can't wait to see your robot. If you need any help at a competition we are in, just ask. |
#10
It sounds like Denman is asking what restrictions there are on bringing plywood products through customs into the United States
apparently there are restrictions on wood products - maybe due to some type of tree fungus? I dont know what they are - but I think this is what he is concerned about if they make plywood wheels, will US custom agents let them into the country? That is the question. |
| What do you use for wheels? | Andrew | Technical Discussion | 36 | 08-01-2004 10:20 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Skyway wheels w/o bearings | ahecht | Technical Discussion | 4 | 22-01-2002 01:25 |
