Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 03-02-2004, 12:24
sscanf sscanf is offline
sscanf is an unknown quantity at this point
Question User_Autonomous_Code() questions
OK. I'm new to FIRST but not new to C. I'm trying to understand the default FRC code. I see that main is calling User_Autonomous_Code() when the autonomous_mode flag is set and after calling Process_Data_From_Master_uP(). like so:
while (1)   /* This loop will repeat indefinitely. */
   if (statusflag.NEW_SPI_DATA)
      Process_Data_From_Master_uP();
      if (autonomous_mode)
        User_Autonomous_Code();
    Process_Data_From_Local_IO();
} /* while (1) */
What I don't understand is Process_Data_From_Master_uP() will in-turn call Default_Routine() which handles the operator interface. This doesn't seem correct but maybe I'm mis-understanding something.
It seems to me that the if check in main should be something more like this:
      GetData(&rxdata);
      else
         Process_Data_From_Master_uP(); //Modify to remove Get/PutData()
      PutData(&txdata);
} /* while (1) */
I'm operating remotely from my team and finally got a hold of the edu robot kit and have managed to program and download it. I got started on this because there is no autonomous mode in the edu default code and want to add it, somehow simulating the autonomous_mode.
I want to be sure I'm not misunderstanding anything before I procede.
Thanks.
Dan Rasmussen
Unread 03-02-2004, 13:15
Re: User_Autonomous_Code() questions
It's not you.
I think there have been quite a few late, late nights at IFI getting this stuff ready, and you know there's always a bug in software. You just may not know what it is yet.
We changed this around to where it made sense as you have done.
We decided to go through Process_Data_From_Master_uP() to check switches like the competition bit, then do the branch to auto or driver code.
Ours looks like:
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
    {                                 /* I'm slow!  I only execute every 26.2ms because */
                                      /* that's how fast the Master uP gives me data. */
      Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
      Process_Data_From_Master_uP();  /* Process switch/joystick changes */
      if (autonomous_mode)            /* DO NOT CHANGE! */
        User_Autonomous_Code();    /* Autonomous drive controls */
      else
        User_Driver();                     /* User driver controls */
      Generate_Pwms(pwm13,pwm14,pwm15,pwm16); /* N/A for EDU */
      Putdata(&txdata);             /* DO NOT CHANGE! */
Unread 03-02-2004, 15:13
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'm not sure about this, so don't quote me, but I believe you are actually able to read the operator inputs once at the start of the match. For instance, assuming that is true, you could have your autonomous function selected by switches that are part of whatever panel you have for the drivers instead of them having to be on the robot.
Of course, maybe I'm wrong and the thing is just incorrectly written...
Unread 03-02-2004, 15:21
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This is based on last year, but I think it still applies. During the competition, when you turn the robot on it is in Disabled mode. The information from the OI is still being sent to the RC but the RC outputs are disabled. We had a thumbwheel switch (little plastic digit with a button to increment/decrement) on the OI to pick the program. While the robot was disabled we updated a global variable with the program number from the OI. Once autonomous started we used that global variable to pick which program to run.
Unread 03-02-2004, 15:25
Programming User
And they all told me it was impossible when I suggested that...
Unread 03-02-2004, 15:33
None #0116
Don't hold me to it, this is pure speculation. You can build the competition mode dongle using the plans on IFI's web site and test it for yourself.
Unread 05-02-2004, 19:58
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
can you help me?
I have pasted a code in the part that says "add your own autonomous code here",.
Then I Closed the switch in the competition port, the controls disable, but autonomous didn't run.
What should i do?
Thanks.
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 06-02-2004, 15:01
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Close the switch for auto mode. Check the doc on IFI's site. But be careful: I already fried our OI doing that ("This is what happens when programmers get bored ...") Fortunately, That was Saturday and we got back Thursday .
Unread 07-02-2004, 07:16
Programming User
Instead of risking frying stuff , for testing you could use preprossesor directives to make the tests for autonomous mode always true when a certain macro is/isn't defined. Something like this:
main.c (in main())
 #ifndef AUTO_TESTING
 #else
 #endif
user_routines_fast.c (in User_Autonomous_Code())
 while (autonomous_mode)   /* DO NOT CHANGE! */
 #else
 while(1)
 #endif
 	  Getdata(&rxdata);
 	  autonomousRun(autonomousModeSelection);
 	  Putdata(&txdata);
auto_testing_setting.h
 #define AUTO_TESTING
Just #include auto_testing_setting.h in main and user_routines fast and your autonomous stuff will run. This doesn't stop after 15 sec, but it can be useful for testing your IR homing works or something like that.
Don't forget to comment the #define out when you're in competition.
3 Questions!!! (1/5/04) Andy Grady General Forum 8 05-01-2004 16:01
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
height questions Team461 Off-Season Events 3 29-10-2001 21:51
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
