Go to Post If you aren't sure, Q&A. Now. - EricH [more]
Unread 03-02-2004, 15:45
ZeoFateX ZeoFateX is offline
None #0637
Team Role: Communications
ZeoFateX is on a distinguished road
Re: Need Help: Build/Make Error
Ok I'm at school now, we tried downloading the files over again, and this time we have a different error:
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\FIRST 2004\user_routines.c:191:Error: syntax error
Halting build on first failure as requested.
BUILD FAILED: Tue Feb 03 15:42:53 2004
Which points to:
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Commenting this line allows us to compile without errors, but this obviously is not the right way to go because errors are not something (visible or not) which we want lol.
We're seriously having problems considering nothing was changed...
Mplab startup error Team 869 Programming 6 25-01-2004 10:41
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
programming error agenova Programming 1 20-02-2002 13:00
