Go to Post Hey Don, if the [Woody Flowers] award doesn't impress the non-FIRST friends and family, just tell them you have your own "inter-web thread" - tell them you are like a Chuck Norris on the internet!!! - ebarker [more]
Unread 02-02-2004, 16:03
ZeoFateX ZeoFateX is offline
None #0637
Team Role: Communications
ZeoFateX is on a distinguished road
Unhappy Need Help: Build/Make Error
I'm not the programmer for the team, but none of them signed up for an account at Chief Delphi -- so I'm posting for them.
We get the following error when we try to compile the program using MPLAB...
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\First\EDU_Default_Code_2003-12-15\ifi_picdefs.h:1288: *** Error - Invalid 18f8520 header file!
error 1 spawning c:\mcc18\bin\cpp18
Halting build on first failure as requested.
BUILD FAILED: Mon Feb 02 15:47:54 2004
We've searched and searched and found no-one else referring to this error (probably a stupid mistake). We DO have the include and library directory set up in Project-->Build Options-->Project (C:\mcc18\h and C:\mcc18\lib), it just won't work =\.
Any help would be greatly appreciated!
Thanks,
Greg Zanone and Team 637
Unread 02-02-2004, 16:21
Electrical Engineer
Rookie Year: 1995
Re: Need Help: Build/Make Error
Thanks,
Greg,
Line 1288 is designed to give you an error if the ifi_picdefs.h file has been loaded more than once (BANKED = 1). However, I am not sure how you did it...
Regards,
Mike Betts
As easy as 355/113...
Unread 02-02-2004, 16:46
Is this the unadulterated EDU default code?
As you can see from the error message, the error you are seeing is due to line 1288 in ifi_picdefs.h. It's finding that you've defined the macro BANKED when you shouldn't have. As you can see in ifi_defs.h BANKED is defined after this check. It's unclear how you were able to do this.
Possible explanations include:
- The files have been corrupted or modified in some way.
- You built a new project incorrectly or missed a file.
- You commented out the lines:
#ifndef __ifi_picdefs_h_
#define __ifi_picdefs_h_
AND included ifi_picdefs.h twice in one file.
This is what a successful compile of that default code should look like:
Deleting intermediary files... done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mplink.exe" /l"c:\mcc18\lib" "18f8520user.lkr" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\ifi_utilities.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\main.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\printf_lib.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\ifi_startup.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\user_routines.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\user_routines_fast.o" "C:\FIRST\EDU\EDU_Default_Code_2003-12-15\ifi_library.lib" /m"EduCode.map" /o"EduCode.cof"
MPLINK 3.40, Linker
Copyright (c) 2003 Microchip Technology Inc.
Errors    : 0
MP2COD 3.40, COFF to COD File Converter
Errors    : 0
MP2HEX 3.40, COFF to HEX File Converter
Errors    : 0
Loaded C:\FIRST\EDU\EDU_Default_Code_2003-12-15\EduCode.cof
BUILD SUCCEEDED: Mon Feb 02 16:26:37 2004
Unread 02-02-2004, 19:12
None #0637
Cool Re: Need Help: Build/Make Error
Thanks, I'll see if this helps after school tomorrow. We've been going bonkers trying to figure out what was wrong lol.
Thanks,
Greg
Unread 03-02-2004, 11:22
Thanks,
Greg
Oops!
There's a more reasonable explaination I brushed over.
You may have defined BANKED somewhere in your code.
e.g.,
#define BANKED 999
#include "ifi_default.h"
//or
#include "ifi_picdefs.h"
would also cause the problem you saw.
This would conflict with the #define BANKED IFI created in ifi_defpics.h.
You have to make sure you don't declare macros, variables, routines, etc. by the same name used elsewhere. If this is what you did, you'd normally get a duplicate declaration error, but you happened to pick a define that's used for an error check and got that error message first.
Unread 03-02-2004, 15:19
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I counted the characters in the path/file name and you should be fine, but just as a possiblilty, you may be exceeding the 64 character limit on the path/file name in some other file. It probably isn't that, but if all else fails...
Unread 03-02-2004, 15:45
None #0637
Ok I'm at school now, we tried downloading the files over again, and this time we have a different error:
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\FIRST 2004\user_routines.c:191:Error: syntax error
BUILD FAILED: Tue Feb 03 15:42:53 2004
Which points to:
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Commenting this line allows us to compile without errors, but this obviously is not the right way to go because errors are not something (visible or not) which we want lol.
We're seriously having problems considering nothing was changed...
Unread 03-02-2004, 16:05
Electrical Engineer
Rookie Year: 1995
...BUILD FAILED: Tue Feb 03 15:42:53 2004[/code]
Which points to:
Commenting this line allows us to compile without errors, ...
Please read http://www.chiefdelphi.com/forums/sh...=generate_pwms which may help...
Mike Betts
Unread 03-02-2004, 16:32
Which points to:
This is FRC code, whereas, before you talked about EDU code.
What default code are you using and which controller?
The code looks like the FRC default code.
If you are loading the FRC default code onto the FRC then you might be missing a macro setting in MPLAB.
In MPLAB go to Project -> Build Options... -> Project
Click the "MPLAB C18" tab on the pop-up window that appears.
and see if "_FRC_BOARD" is defined under Macro definitions.
If not, click on "Add" and type in "_FRC_BOARD", click OK, close the pop-up windows and try building again.
Unread 04-02-2004, 10:56
None #0637
Talking Re: Need Help: Build/Make Error
Loaded C:\FIRST 2004\FIRST 2004.cof
BUILD SUCCEEDED: Wed Feb 04 10:54:12 2004
Thanks ^_^
Team 637
Mplab startup error Team 869 Programming 6 25-01-2004 10:41
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
programming error agenova Programming 1 20-02-2002 13:00
