Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 03-02-2004, 17:02
Obi's Avatar
Obi Obi is offline
Obi is an unknown quantity at this point
IR from scratch
I'm one of those programmers who needs to know how everything works in a code to learn. I don't like using code designed by someone else, besides just learning from it. Now, to the point...
Is it possible for me to just put the IR sensor on a digital input on the default code? I've been trying the sensor on a dig i/o. I told it to print the value to the terminal IFI loader screen, but it only equals 1, even when the sensor is not in. Am I doing something wrong?
[hr]
Southold Robotics Team #870 (RICE)
Unread 03-02-2004, 17:54
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Re: IR from scratch
The sensor goes from high to low many times a second with the beacon working properly. You need to "measure" the low times in order to find out which beacon it is. This will also allow you to search for it.
Unread 03-02-2004, 17:55
Obi's Avatar
Obi Obi is offline
Re: IR from scratch
How do you "measure" the values?
[hr]
Unread 03-02-2004, 18:43
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Re: IR from scratch
One way of doing it is putting it on an interrupt. The robot controller just does not poll digital inputs fast enough to pick up the signal. Another way would require you to design an external circuit with a memory chip on it that would store several bits before being read (and cleared) by the RC. This would be quite complicated to do properly in 3 weeks so just go with the interrupts.
Unread 03-02-2004, 19:01
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR from scratch
Start with the FAQ and then get a copy of the code and start with receiver.c. Once you understand what's going on there, start working on understanding the code in tracker.c. The interface between the two pieces of code is the structure "Sensor_Stats". Once you've mastered that, move on to navigate.c.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-02-2004, 21:27
Re: IR from scratch
Even on a polled digital input you should be able to see 0's mixed in with the 1's even pointing most IR rmote controls at the sensor. However, as others have noted you won't be able to use this on a competition robot, because you cannot poll it fast enough to follow the beacon sequence of IR flashes.
Unread 05-02-2004, 16:04
Obi's Avatar
Obi Obi is offline
Re: IR from scratch
All I get when I print the command to the screen are 1's.
[hr]
Unread 05-02-2004, 16:26
Re: IR from scratch
Are you using your beacon to generate the IR or something else?
I have encountered IR remote controls that aren't broadcasting at the 40kHz of the IR sensor, and so don't get detected.
Double check your IR sensor hookup. Looking at the from of the IR sensor:
pin 1 (on the left) should be your white or signal wire,
pin 2 (middle) should be your black or ground wire,
pin 3 (on right) should be your red or 5v wire.
Try a different IR sensor in case it's bad.
Have you verified the operation of your beacon?
Here's some code to double check your setup. This code runs everything (beacon included) on the FRC. See the ReadMe for what's connected to what. I setup digital IO pin 6 to do what you're attempting with the IR sensor. You can use this to see if the problem is with the sensor or beacon before you go too crazy.
Oops. I mistyped rc_dig_in06. You'll see it when you build. Sorry about that chief.
Buckeye Webcast soap108 Regional Competitions 7 07-03-2003 10:44
Thoughts...King of the Hill Justin Rules/Strategy 32 16-01-2003 11:15
Who had the coolest wheels? Greg Perkins General Forum 24 05-05-2002 23:59
Shop from scratch Keithicus Technical Discussion 4 18-01-2002 16:04
2001 Scratch Awards Andy Grady General Forum 12 04-10-2001 22:04
