Go to Post I told myself I'd stay out of the obsession this year, but I couldn't resist... - Grant Cox [more]
Unread 03-02-2004, 20:59
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Optical Sensor Output Overload
Hi!
Hey squide, the reason you have an overload is that the input for the sensor is 12vdc. Therefore, if you have it hooked up incorrectly, the signal will also be 12vdc when the switch is closed. That's really bad. the controller is only supposed to be getting 5vdc signal or 0vdc signal, but never 12vdc. The robot controller is pretty tough, so I do not think you will have fried it, but you will not get a consistent reading until you fix this. I have a schematic that I will be posting soon.
-Sparks333
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
