Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 03-02-2004, 21:18
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: Optical Sensor Output Overload
Originally Posted by Sparks333
Hi!
Hey squide, the reason you have an overload is that the input for the sensor is 12vdc. Therefore, if you have it hooked up incorrectly, the signal will also be 12vdc when the switch is closed. That's really bad. the controller is only supposed to be getting 5vdc signal or 0vdc signal, but never 12vdc. The robot controller is pretty tough, so I do not think you will have fried it, but you will not get a consistent reading until you fix this. I have a schematic that I will be posting soon.
-Sparks333
The inputs are pulled up to 5 volts internally, so they're expecting to see either an open circuit or ground. The Banner sensors have an open collector output so its just like a switch. Its either open or grounded, there is no output voltage.
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
