Go to Post Guys wearing pink, that strikes fear into my heart now :). - Cyberguy34000 [more]
Unread 03-02-2004, 19:41
santyclaz santyclaz is offline
santyclaz is an unknown quantity at this point
Connect Conveyer Belt to self
how do you connect conveyer belt to itself? they come in strips so when you wrap it around something how do you connect the ends? thanks
Unread 03-02-2004, 20:54
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Re: Connect Conveyer Belt to self
they sell endless and the non-endless kinds
for robot use you want the endless ones. (they come in a single peice)
Unread 03-02-2004, 21:55
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
You could try something like the super market has, where there are just hundreds of staples lined up in a row. I wouldn't suggest it, but its worth a try.
Unread 03-02-2004, 22:11
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
I believe they are typically sewn. You'd need a really really industrial strength sewing machine to do it, though! That stuff is tough!
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 03-02-2004, 22:16
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Most of the ones I've seen have been sewn also. Depending on what you're doing with the belt an industrial contact cement may also work.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 03-02-2004, 23:09
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
the endless belts are usually welded together, well thats what the conveyor belt ppl tell me, but the ones that come in stripes usually have a lot of small hooks and the end and you stick a rod through them to hold it together (just like door hinges in your house)
Unread 04-02-2004, 02:21
oh alright thanks for all the input
Unread 06-02-2004, 01:45
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Yes, you CAN buy them preformed in an endless loop, but there is a specialized hydraulic press "staple gun machine" that does the "long stapling" which conveyor belt suppliers use to convert linear stock into loops. This is that "staple row" you see on supermarket belts.
The staples are prefabricated into V-strips, with the tips of the V bent over and pointing at each other. Think of this staple run as looking a LOT like the end view of a standard office "staple claw". The strip is dispensed from a giant reel, and is cut to the length needed for the job. When you squeeze the sides, the two sides will "inject" themselves permanently into the belt from each side, like a gripper closing. The wire the staples are made out of is somehing like spring steel. Therefore, it takes a LOT of pressure to perform a permanent deformation of the metal...
Procedure they use (I've watched it performed while making our team's belts ):
1) Cut the belt to the length and width desired.
2) If using a gummy-belt (or other "treaded" belt), you first have to shave off a strip of the raised nubs, to give you a flat surface for the staples!
3) Cut two appropriate lengths of the V-staples from the supply reel. Depending on the size, you may use either heavy duty diagonal, or bolt cutters.
4) Load the specialized hydraulic press die with the V-staple run. Insert the trimmed end of the belt into the die. (The die keeps everything in line.)
5) Cycle the air or motor assisted hydraulic press, with a few tons of force...
6) Repeat 2-5 for other end.
You now have what looks like a belt with a series of loops at the end of each one.
7) Place the two ends of the belt onto yet ANOTHER jig, which pulls it so the "loop fingers" interlock.
8) you now take the associated size coated wire, and thread it down the center between the loops to lock them together as a "hinge wire". This may require a jig with a separate squeeze tensioner, to form the space through which you thread the hinge wire.
9) Trim the hinge wire to length and terminate the ends to keep it from slipping out. Options include spot welding it to the wire loops, folding over the ends of the wire, crimping the end with ANOTHER special tool, etc...
So, as you can see, unless a company is a BIG user of belts, the tooling investment simply isn't worth it. It's a significant sized hydraulic cylinder, along with some custom dies for each size of staple. That's why you normally have the conveyor belt distributor to do it for you when you buy the belting from them, as part of the package price (think of it as "buying belts with ends").
Whenever we use a conveyor or a tread, we have the conveyor belt distributor premake our belts (and spares) FOR us. I just have them keep the ends disconnected, and have a short supply of the Hinge Wire. The TEAM can then insert the wire into the belt like a "key" to lock it together, or pull it out to separate it for servicing or belt replacement. You often have to cut the hinge wire to remove it, which is why I maintained a small supply of matching replacement hinge wire.
OTOH, We have also used gummy belt before as TIRE belting, over a solid wheel. In THAT case, I do NOT connect the ends. We simply cut some to length to wrap the tire. I then use a Dremel and a grinding stone cylinder to "burn off" a series of recessed flats into the tread's rubberized part. I then drill the pilot hole through the belt, and use either pop-rivets or flathead screws to attach it to the wheel itself. This recessing keeps the "screwheads" away from the carpeting. Note you don't NEED to connect the ends of the belt, IF you have screws along the mating edge. I progress from one end to the other, to insure it is kept taut around the wheel.
I hope this helps give you a better sense of how conveyor belts work, and how they're applied.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
FIRST College Connect is now UP!!!! Erin Rapacki General Forum 30 29-06-2007 11:25
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
