Go to Post 20,000 students 900 teams robots Gracious professionalism = FIRST - Bcahn836 [more]
Unread 03-02-2004, 12:31
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: 2x multiplier removal secnario
Originally Posted by robo hottie71
It seems to be a total contradiction on FIRST's part, but then again, they did say "as long as no other rules are violated" or something to that effect. Descoring with the large ball in the robot's possession will violate the descoring and/or goaltending rules, so those should apply, therefore making this move illegal.
Have your human players actually tried shooting into a goal that has a large ball stuffed in it?? Try the ball at different heigh levels and see what happens....
We have and found that it depends on who far the ball is in it. The higher up it is, the harder it is to enter the goal, not only because of the bounce of the big ball, but you can't use the PVC as a slowing device like you can if the ball is in deeper. Here's what I've seen:
-ball thrown straight down don't go in.
-the PVC slows down the balls to let the score
-the gap between the PVC and ball can stop the small balls
The best type of throwing motion is a basketball throw with a big arch that'll hit the PVC, and that will slow down the balls.
Unread 03-02-2004, 12:33
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Will smalls balls stay in a goal that has a large ball smashed in it. It would seem that the PVC would bend far enough that the gaps between the poles would be larger than the small balls. Therefore you would not be able to score small balls on top of a large ball. Has anyone tried putting small balls on top of a large ball already in a goal? If so, please comment on how it worked out.
See you in DC!
Unread 03-02-2004, 16:05
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
I think it's an interesting idea, and I don't think anyone has the real authority to make a ruling on it except FIRST - since it does fall in a VERY grey area of the rules.
I personally would like a definitive answer, since it will determine how many teams with large ball capabilities play the game.
Here's another question - if the enemy team throws balls at your robot while you do this, would it be considered "goaltending" and give a -10 point deduction per ball that hits you?
This is precisely the reason why FIRST should make things spelled out and black and white.
Benjamin Mitchell
Vex Robotics Competition team advisor (4 high school teams)
Unread 03-02-2004, 16:08
Yes, that scenario has already been answered by FIRST.
Q: While trying to put a 2X ball on opponent’s goal, will this be considered goal tending ?
A: Yes, if it interferes with a thrown ball with the potential to go in the goal (referee's judgement). See the definition of GOAL TENDING.
Unread 03-02-2004, 17:01
Heh, so I guess it is safe to assume salvo after salvo of ball being intentionally thrown at your robot while you are capping or uncapping a goal.
Benjamin Mitchell
Unread 03-02-2004, 20:25
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
yes we did. when you have the 2x ball all the down in the stationary goal its hard to get small balls inside the goal since all the pvcs spread out. when you have the 2x ball in the mobile goal still its hard to get the ball in... unless your human player has a very good aim of hitting the pvc pipes first and then let it go in the goal...
Unread 03-02-2004, 20:41
I think this whole thread is arguing over how many angels can dance on the head of a pin
cramming the 2X ball down into the goal just aint gonna happen
besides, if you cram it in your opponents goal, why would you want to take it back out again?
Unread 03-02-2004, 21:59
To deny them a 2x multiplier/remove small balls
Benjamin Mitchell
Unread 03-02-2004, 22:19
blindguyinanorg's Avatar
Happy Birthday! blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Hey look this year your score is based on the loosing teams score. if your robot is good enought to cram and remove a cramed ball the obviose solution is the direct the ability toward increasing your score.
Last edited by JVN : 03-02-2004 at 22:57. Reason: Font was obnoxious... now less obnoxious.
Unread 03-02-2004, 22:20
Matt Spencer
AKA: Sexy Beast
sorry i didnt know 7 was so big HAHAH
Unread 03-02-2004, 22:25
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Okay, to recap this, let me explain two different scenarios that are based on the situation I see.
1.) FIRST keeps the ruling they have. Red alliance shoves ball down Blue Goal. At the end of the match, Red alliance uncaps blue goal, descoring all the small balls. Legal way to descore.
FIRST Intent: Unacceptable
2.) FIRST updates the rule to make it illegal to remove small balls from the goals even through uncapping. Red alliance jams 2x multiplier to bottom of goal. Now they have a guarenteed 2x because blue may not uncap that goal anymore.
The only possible scenario I see, which is insanely hard to referee, would be to count any small ball that went into the goal to be counted, and if it is removed by action of uncapping, it will still be counted towards final score. This raises another problem, but is less major. (The problem of, for every ball removed, theres space for another one yadda yadda yadda...). My dilemma continues.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 03-02-2004, 22:39
I smell a lawyer! :c)
Unread 03-02-2004, 22:55
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Read the rules.
This year's scoring is based on wins and losses.
Loser's score is only important if there is a tie.
Defense is a perfectly viable strategy.
This is a good defensive move, if legal (which I think it isn't).
Read, learn... THEN post an opinion.
JVN
Unread 03-02-2004, 23:08
AKA: Jim Martz
Originally Posted by JVN
Read the rules.
JVN
Neither of my situations should be legal. Catch 22.
...and ken, thats my dad you smell.
Unread 03-02-2004, 23:54
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
The way I see this is that FIRST has said you may uncap a goal and any balls on top are incidental as long as your robot does not touch them. If the robot grabs the 2x ball (instead of simply pushing it out) then the large ball will be part of the robot and in contact with the small balls, therefore ensuing a penalty. So the small balls that come out of the goal without being touched by your robot will not count towards the score. All in all, I think FIRST says you may remove a 2x ball that has small balls on top of it as long as you do not touch those small balls. But how many balls can you really have on top of the large ball? The PVC will bend out of the way.
See you in DC!
*4 multiplier? *8!??!? Mike Rush Rules/Strategy 44 12-01-2004 17:32
Size of 2X multiplier ball Fiona Rules/Strategy 4 10-01-2004 18:54
