Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Unread 04-02-2004, 00:21
roberthan roberthan is offline
None #0702 (Bagel Bytes)
roberthan is an unknown quantity at this point
Send a message via AIM to roberthan
Question How do you program timers?
Newbie here. I need some help on how to program timers for the Frc.
Unread 04-02-2004, 00:33
rdsideresistanc's Avatar
rdsideresistanc rdsideresistanc is offline
AKA: Joel F
#0825 (SWVGS Maximus)
rdsideresistanc is an unknown quantity at this point
Re: How do you program timers?
well, you know that the program loop is approximately 26.2ms, so just start a counter of the program loops and use a conditional to decide when to execute your commands.
so if we use 26ms as our reference,
10 sec = approx. .026s * 385 or 385 program loops....
If you need code examples just ask
Cheers,
Joel
Unread 04-02-2004, 00:46
Thanks alot, I could use some examples and does it work for the autonomus mode?
Unread 04-02-2004, 00:51
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Cheers,
Joel
NO! PLEASE! FOR THE LOVE OF ALL THAT IS THE NEW CONTROL SYSTEM! DON'T DO THAT!
Read MPLAB C18 C COMPILER LIBRARIES, section 2.9 to learn about Microchip's provided libraries for initializing, reading, and writing any of the four available timers on the PIC18F8520. Timer0 is used by IFI for some stuff, I believe, but other than that, you can interact with Timers 1-4, two of which are 16 bits wide, and the other two of which are 8 bits wide. If you have any questions, please feel free to ask.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-02-2004, 02:01
AKA: Joel F
what exactly is the problem with this method?
Unread 04-02-2004, 02:18
Kevin Watson's Avatar
La Caņada High School
FRC #2429
There is example code here: http://www.kevin.org/frc/. The interrupt and timer template code is pretty well documented. The clock demonstration code shows how to setup a timer to create a very accurate clock.
-Kevin
Kevin Watson
http://kevin.org
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Credits for FIRST program. archiver 2000 6 24-06-2002 00:16
An invitation for HS Juniors archiver 2000 0 23-06-2002 22:51
