Go to Post Don't forget Morgan Freeman will be at champs. Maybe he and Will are gonna freestyle it! - Nuttyman54 [more]
Unread 03-02-2004, 22:23
lasindi lasindi is offline
FRC #1164 (Project Neo)
lasindi is an unknown quantity at this point
IFI Loader Problems
We are having troubles with loading HEX files. When I try to open one that I've compiled, I get an error message that comes up that says, "Run-time error '76': Path not found." I've heard that the directory address of the HEX file cannot exceed a certain number of characters. I moved it to a folder directly on the hard drive and I still get these errors. I'm not sure if the connection has anything to with "path" errors, but we are using a USB-to-serial adapter because the laptop that we're using doesn't have any serial ports. We tried to see if we could open a connection with the robot using a different program and it worked. The loader, however, says that it is "Not Connected". Does anyone know how to solve this?
Unread 04-02-2004, 06:10
Electrical Engineer
Rookie Year: 1995
Re: IFI Loader Problems
We use the Bafo USB to serial converter suggested by Dr. Johnson (do a search on "Bafo") and have had no problems with any PC connecting to last year's or this year's controller.
One thing to check is which COM port your USB converter is connected to (it can be different each time it is unplugged/plugged into the USB, depending on other things being used in your system.
As far as the path not found statement, I don't have a clue. I'd try reinstalling the USB driver as I am not sure if the IFI loader is generating the message...
Good luck.
Mike Betts
As easy as 355/113...
Unread 04-02-2004, 11:31
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
That error sounds familiar. I got it just last night after installing all the tools on a new laptop. Windows 2K SP4. It was an "Argh" moment.
I'm not sure what I did to solve it. I think my solution was to uninstall (using control panel/AddRemove Programs) and reinstall IFI loader. I think I chose to install version 1.0.6 instead of 1.0.7, just to see if that made a difference. Things worked well after that -- I don't know what exactly fixed it.
Hope that helps.
-Norm
Unread 04-02-2004, 15:06
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I think I might have seen this message when my .hex file was located too deep in the directory tree. (i.e. the file path was more than 64 characters.) If this might be your problem, you could try moving your project directory closer to the root.
Unread 04-02-2004, 16:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Some suggestions:
1. Try recompiling the file and moving it to the root of the drive.
2. Reinstall the software, it's kind of tempermental.
3. Find a computer with a 9-pin serial port. I don't see why this would cause a path error, but you never know. Might be a badly written error message.
Hope you get it working!
Unread 04-02-2004, 20:46
nevrgonastopme0 nevrgonastopme0 is offline
~~The One and Only!~~
AKA: Kris
#0279 (Tech Fusion)
nevrgonastopme0 is an unknown quantity at this point
Send a message via AIM to nevrgonastopme0 Send a message via Yahoo to nevrgonastopme0
yeah, we had this problem too, I also dont remember what we did to fix it, but I think I uninstalled it, moved the code to a folder right on the root drive *C:\* and set up the output in the build options to go to that folder. it worked, I might have done something else too that i dont remember, but after i did that, it wouldnt find the COM port.... I know for a FACT that the problem your having dosent have anything to do with the COM settings, it can occur later, but thats not the case right now, its something with the compilleing...also make sure your saying build-all not just make, dont know if that would change it, but it never hurts to try...
Kris
Last edited by nevrgonastopme0 : 04-02-2004 at 20:48. Reason: had to fix stupid smily thing...
Unread 05-02-2004, 06:06
Electrical Engineer
Rookie Year: 1995
Kris,
It sounded like a two problem problem. Lasindi indicted "no connection" AND the path error. The two may be independent...
Regards,
Mike Betts
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
