Go to Post Many of us are engineers who value precision and accuracy in communication. Words mean things. - Alan Anderson [more]
Unread 03-02-2004, 21:31
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
# of Gauges
How many gauges did you guys get in your kit this year? I was trying to put together a working model of the pneumatics system we are going to use and I noticed we only have 2 Gauges and 2 valves.
I looked on the picture they gave us and it has 3 gauges... and they all seem to have a max of 160PSI. We have a 160psi and a 60psi
Can someone clear this up for me?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 04-02-2004, 12:46
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Sorry, only two comes with the kit...
You might say the picture (Pneumatics manual, page 15) is "wildly optimistic"...
...Or maybe THEIR pair of 160's bred a third one (and that's why we can't get another... It's still a 60 PSIG "child"...)
Seriously though, according to page 7 of Rev A of the KOP document ("6-TheKit-RevA-markup.pdf"), there are only TWO regulators supplied, both labeled as being 160 PSIG. However, I think that's a misprint. For the last few years my teams have only received "one of each", one in the 120-160 range, and one at 60. This year, we again only received one of each as well: one 160 PSIG max, one 60 PSIG max.
The advantage of having at least one 60 PSIG gauge is that (a) you don't NEED two higher pressure ones, and (B) you have higher resolution viewing of a dialed in pressure on the "working side" of the main regulator.
But I agree with you that we REALLY need a third gauge, so that you can monitor (A) pump/tank, (B) primary line post primary regulator, and (C) post secondary regulator pressures.
Bear in mind that you DO have a third gauge in the KOP: the TI pressure sensor. If you wish you can use the control system itself for the third gauge. You simply stick the value in a variable, and display the pressure on a laptop or a Palm Pilot monitoring that variable via Dashboard Port. Though less convenient for debugging, it saves you the price of another gauge on your BOM, and it can be buried in a less viewable place.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
looking for voltage and current gauges . . Frank(Aflak) Electrical 1 07-12-2003 22:32
Pressure Gauges RAWdealer59 Pneumatics 3 18-02-2003 23:37
