Designs for control board?
I'm currently working on a design for our control board. It has to allow for roughly 20 switches and two joysticks. Help soon pretty please? ^^
Re: Designs for control board?
If you require 20 switches to operate your robot in the match, rethink your control system. Anyways, suggestions for this would have to be to build on station for joysticks for your driver and one station for your operator to stand next to the driver to use. 108 always uses lexan or plexiglass on our controllers because its pretty, heh. Gimme a shout @ aim screenname: specialagentjim and let me know what in the world you need 20 switches for. |
The OI can't even handle 20 switches! It only has 4 digital inputs on each port -- a total of 16. If you really need that many switches, you might be able to do something with some of the analog inputs, though I'm not sure how that would work.
That's a lot of switches... A few years ago we had 4 switches, and it required a lot of practice to push the right one at the right time, i wish you luck in programming and implementing that. is there not a more efficient way to use the joysticks? they have some buttons... as for the 2^16 combinations, that's an interesting idea, but reeeeaaalllly complicated. it's true, but i don't think my team would have had time to wire/program something like that, let alone have it work and practice/debug it. anyway, that's a lot of functions. if 20 switches means 40 functions, you'll probably need at least 2 of the inputs, if you try the combination method.
| Shelf and board dimensions still don't add up | kmcclary | Off-Season Events | 12 | 20-10-2001 09:12 |
