#31
Re: What do you think of a wedge
I think I led the thread off topic when someone stated they wanted a defensive wedge on their bot, because they expect to get bashed when minding their own business - collecting balls, capping goals.
I tried to point out that should not be necessary, such teams would get disqualified... but back to the idea of wedges - if you put one on your bot, does it fold down after t=0? I would think to be effective it would have to extend out, and you wouldnt want to pull your wheels inside the 30 x 36" footprint to make room for wedges - that would make you less stable. As a rule, you want your wheels touching the floor as close to the edge of the space footprint as possible - "Wider is better!" |
#33
-Joel |
#34
hey can I borrow that bot this morning?
can it be programmed to go back and forth and back and forth on my driveway in auton mode? I would think you would want a sharper edge on it than that to deflect an attacker upwards. How well did that work? also, if the idea is to be protected while 'minding your own business' wouldn't you need a wedge on at least 3 sides of your bot this year? if you have to spin around to point your wedge at an attacker, I dont think you will be able to continue to collect balls, or do what you want with the 2X ball the protection would have to be passive - like a turtle :c) Last edited by KenWittlief : 24-01-2004 at 07:35. |
#35
That was an ingenious device. We never saw it coming because, as you said, we had not seen you use it before. This was an example of a simple device to overcome another robot's strengths. This incident led to our design last year where no one ever got beneath us while our wings were down. |
#36
Our robot was shaped like a wedge last year in stack attack... its a simple and easy design (we were rookies... so easy was good for us)... it works fairly well, but its a little top heavy... we almost tipped ours last year going up the ramp...
| The Wedge Bot!!! | Parks | Regional Competitions | 22 | 30-03-2003 16:05 |
| Wedge and Solenoids | archiver | 2001 | 3 | 24-06-2002 00:17 |
| didja see the wedge? | Gary Dillard | Championship Event | 7 | 30-04-2002 21:55 |
| Fork Lift Robot | tinyfarnsworth | General Forum | 64 | 16-04-2002 12:09 |
| Chief Delphi 7 veiled - Look close | Mike Martus | Robot Showcase | 21 | 21-02-2002 13:57 |
