Go to Post not national champ.....WORLD CHAMPION - Stephen Kowski [more]
Unread 04-02-2004, 18:30
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: How do the servos work?
Originally Posted by zainali
We don't want the servo to rotate more then it is doing right now.But we were wondering if servos can be made to rotate backwards. This is because everytime you make it turn you have to manually twist it back to its starting position to make it turn again.
I think you first need to understand how a servo behaves. Unlike a motor, you do not give a servo a speed, you give it a position. If you directly map a motor to the y-axis of a joystick and push the stick half way forward, the motor will run at half speed until you release the stick, then it will stop. If you do the same with a servo, it will rotate half way to one end and stay there, then when you release the stick it will return to the middle. The servo is actually a motor and a potentiometer all in one, it performs the whole feedback loop for you. You give the servo a position (from 0-255) and it goes to that position and stays there until you give it a new position. They're actually pretty cool little devices.
using older servos pryoplasm Kit & Additional Hardware 4 24-01-2004 20:22
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
