Re: Gear Help Needed- Urgent
You can also try MSC (www.mscdirect.com). We deal with them and they are very good, and in most cases you get your order the next day. From what I've been told acetal is a type of plastic. I've also seen nylon gears. I'm not sure of what you're doing with them but just make sure that they're strong enough (hold up) for what you're going to do.
I concur. Make very certain that the gears will be strong enough. Aluminum might be strong enough for what you're trying to do, but you might want to make some calculations first. If it's not strong enough you'll strip gear teeth really quickly.
Here's a link to Martin Sprockets with everything you should need to figure out the allowable torque for a gear. Martin Sprockets |
materials for gears:
steel- used for high tourqe high speed operations aluminum - used for less strain all around use plastics - used for low power and general opperation many for wet enviorments in most places you can buy gears there are strenth/ speed ratings check those vs the opperation they are for before buying |
Thanks for the quick response, you helped a lot
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain help | thedillybar | Technical Discussion | 9 | 08-01-2002 21:54 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
