Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 04-02-2004, 22:19
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 954 Preview: Heavy duty Master Link
Unread 04-02-2004, 22:22
David66's Avatar
David66 David66 is offline
YA TOAST!
AKA: David Butzin
FRC #0066 (The Flyers)
David66 has a spectacular aura aboutDavid66 has a spectacular aura aboutDavid66 has a spectacular aura about
Send a message via AIM to David66 Send a message via Yahoo to David66
Re: pic: Team 954 Preview: Heavy duty Master Link
WARNING!!! I can absolutely, and without a doubt garuntee that if you use the drill motor in that manner without supporting that shaft BEHIND the gear the transmission will snap off the motor in the middle of the match. it WILL happen, no questions about it. I speak from person experience of doing the EXACT same thing. Also, bracing the shaft from in front of the gear will not work. It needs to be supported between the transmissiona dn the gear. Please please please contcat me with ANY questions
Proud Alumni of Team 66
2005 Great Lakes Regional Champions with Team 67 (HOT) and Team 68 (Truck Town Thunder).
2005 West Michigan Regional Champions with team 107 (Holland Christian High School) and Team 93 (New Apple Corps)
2002 National Champions
Unread 04-02-2004, 22:31
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
I can see yu reason for concern, but when i look at the picture, i see ply wood, and tape, i think this bot is FAR from done!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 04-02-2004, 22:34
dhoffman dhoffman is offline
#0954 (Scorpion Robotics)
Team Role: Student
dhoffman is an unknown quantity at this point
Send a message via AIM to dhoffman
Thanks for the warning! This was just a mock up for a picture/non driving prototype - on our "final robot" we have pillow blocks supporting the shaft on both sides of the sprocket (the dirlls are moved back). Thanks for the suggestion though, my team is new to Chief Delphi and we appreciate the caring attitude of the members. Thanks again.
Scorpion Robotics
Unread 04-02-2004, 23:41
REVving up for a new season
FRC #2848 (All-sparks)
i personally disagree with the coments of supporting the shat infront of the tranny and after the gear. the rule of thumb is that you put 2 bearings on a shaft which is true but in the case of the drills the transmission acts as the bearing on the motor side and putting another pillow block there unless all three (2 pillow blocks, and the tranny) are exactly lined up will work against you and make your drive more effiecnt. about the issue of breaking the tranny in half i only saw that last year when the end beyond the sprocket wasn;t supported. other then that they shouldn;t have broken unless there was something unrelated as the cause
Unread 04-02-2004, 23:58
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
I am deeply concerned about the sprockets you are using... LOTS OF WEIGHT!!!!
If you can get the same gear reduction with smaller gears... use the smaller ones.... and from the looks of it, it looks like a one to one so you don't need such bulky sprockets anyway
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 05-02-2004, 00:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That is definitely not 1:1. Looks way closer to 2:1. There is a lot of unnecessary weight on there though. You could drill out quite a bit of it, very easily.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-02-2004, 00:11
Team Role: Student
Thanks again for all of your concern - as you can all probably tell our team is still very rookie in nature. As far as the sprockets go, we are using smaller one's on the "real robot" - and just for your general info the picture shown does have reduction, it's something like 45 to 30 or around that area. Now, since our motors have not been totally mounted on the finalized design and we could gain more space by not having the second pillow block, since we have two differning opinions on the neccessity of an additional pillow block, could an additional person (or a few?) please clear up if we need an additional pillow block or not?
Scorpion Robotics
Unread 05-02-2004, 07:12
David66's Avatar
YA TOAST!
AKA: David Butzin
To clarify my earlier post: Last yearwe used almost the exact same type of drive system (concerning the drill motor/trans) and supported the shaft only after the sprocket. This leaves only the plastic bracketry holding your trans in place-plastic flexes. When we put a high torque load on any of these motors the plastic would flex allowing the gears inside the trans to bind and fling the whole thing to pieces . If you watch some videos from nationals you will often see judges walking around with magnets after one of our mateches...thats our drill trans being picked up. However, for the absolute best information there is a team on here that proudly defends the 2003 drill motor and gearbox (294?). Look for one of them for the best answer.
Unread 05-02-2004, 09:45
#1011 (CRUSH)
It is always a good engineering habit to take the side load off of your motors. Without the second pillow block, what happens is that your motor is now being pulled from side to side. This is often the number one reason for the magic smoke
One pillow block on each side of your sprocket will save your motors a lot of stress
Here is what we did last year to show you what I mean:
Unread 05-02-2004, 12:52
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
do u no what heavy duty actually means?
Unread 05-02-2004, 13:53
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: pic: Team 954 Preview: Heavy duty Master Link
I'll completely second that opinion.
The bearings inside the drill motor (and almost all motors) are probably awarded to the lowest bidder... do you want that supporting your drive train? I know I wouldn't!
Also, make sure you double check your gear ratios.. from past experience, I know that if you're using just the drills and want to make sure you don't blow your 40 amp circuit breakers, the proper ratio from low speed is (roughly):
Wheel diameter in inches * .375 = total gear ratio speed reduction
Go with two pillow blocks!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 05-02-2004, 14:09
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Definitely go with two pillow blocks.
Pillow Block - Sprocket - Pillow Block - Drill Motor Transmission
-Joel
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
