Go to Post I used to wonder if the FRC staff would read the CD game hint posts and just laugh to themselves..now I know they do. - rachelholladay [more]
Unread 04-02-2004, 19:52
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
back-driveable vs. not
Does "non-back drivable" mean that a motor can't be turned when off? Or can it not go in reverse? Or not be pushed backwards while going forwards? And are the window motors non back-driveable, meaning when suspending the robot via winch they won't release when turned off?
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 04-02-2004, 20:10
Pyro16 Pyro16 is offline
AKA: Kevin Kusiak
#1251 (TechTigers - The Revolution)
Pyro16 is on a distinguished road
Send a message via AIM to Pyro16
Re: back-driveable vs. not
I’m pretty sure that it means that it can’t be moved if its off. If it’s the window motor it does goes in both directions and I don’t thing will turn because it’s a worm drive.
Why don’t you test it to make sure?
-Kevin Kusiak-
A member of team 1251
Awards-
2004 UCF regional, Rookie Allstar
2005 Palmetto Regional, 1st seeded and finalist w/ 25 and 301
2005 Palmetto Regional, Xerox Creativity Award
2005 UCF Regional, 3rd seeded and finalist w/ 845 and 1270
2005 UCF Regional, Judges Award
Unread 04-02-2004, 21:17
dont try to find out by testing it - someone on here should know one way or the other
if it is a high ratio worm gear and you try to force it, you can strip the teeth off the gear - then how will it be able to eat steaks or apples?!
Unread 04-02-2004, 21:25
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
non backdriveable means that you cannot physically move it (in either direction). Only the motor can move it. One way to do this is with a worm drive (although worm gears with pitch larger than ~10% can be backdriven).
Here is more info on the window motors (found by searching CD):
The anti-backdriving capability of those motors is awesome, so we try to use it to our advantage. Modifying the motor is just not allowed within the rules.
I know you don't want to argue the point, but I just can't help myself. The seal drag and other resistive forces are nothing compared to the weight of the window. Even though the window is going down, gravity is still acting on the motor (just helping). The motor's backdriving resisistance (or the linkages' backdriving ability) allows the window to stay up when the motor is off. The second the motor starts to move, the backdriving ability of the worm is greatly reduced (sliding friction vs. static friction) and gravity actually pulls the window down and the motor just controls the fall.
http://www.chiefdelphi.com/forums/sh...50&postcount=8
-Matt Durstenfeld
Unread 05-02-2004, 07:49
Stephen P's Avatar
This anti-back drive device may be adequate for suspending a 5 pound window, but what about a 130 pound robot?
Unread 05-02-2004, 08:59
its not only designed to hold the car window open, but to prevent a thief from pushing it down and to keep the windows from sliding down when the car hits a pothole.
Unread 05-02-2004, 10:47
FRC #0701 (RoboVikes)
i'm not sure about the window but i can guarentee (is that how u spell it?) that van doors can be back driven w/ a 130 lb robot!
Team 701
Unread 05-02-2004, 11:14
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
The Van Door Motor is designed to be back driven (so you can open the doors of the van manually in case the motor fails).
The window motor is designed NOT to be back driven (so people can't break into the vehicle).
I would be willing to bet that the window motor cannot be back driven due to the weight of a 130 lb robot.
Unread 05-02-2004, 11:46
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
Facts
We have used the window motors for 3 of the past 4 years and in every case they did not back drive.
1. 2000 used as our winch motor and hung after the power was shut off
2. 2001 used as our conveyor extender motor and held 200 lbs of pre-load without back driving
3. 2003 used as one our strap motor and one as our bin lift motor. Neither were backdriven. The bin lift motor held me up (180 lbs) when it was shut off.
This year we will be using the window motors for an application that requires them to hold position while turned off.
-Paul
Unread 05-02-2004, 21:58
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You cannot make a statement as simple as this. There is a torque at which something will give. In this case, the worm gear will probably be the first thing to break. The torque backdriving the motor depends on not just the weight of the robot, but also the radius of the winch. i.e. if the robot weighs 130lb and is directly hanging from a winch of radius of 0.1 feet, you will have 130*0.1 = 13ft*lbs of torque acting on the motor. If someone has some data on these motors, that would be great.
Team 1257
Unread 05-02-2004, 23:38
Dick Linn's Avatar
no team (Synergy)
There are other older threads on the door motor/winches. I suggest searching the forums and you'll get some good info. We put a winch spool on the van door motor assembly (maybe 1 1/2 diameter in the center and 3" for the end plates. You can turn it relatively easily by hand, so we are putting a positive hold mechanism (like a cleat or an ascender for rock climbing) onto the cable to keep it from unreeling once we lift.
Worm drives can definitely be back-driven if the lead angle is too great. There is some info about this at bostongear.com at http://www.bostongear.com/products/enclosed/faqs.html (and possibly in the "gearology" tutorial, too) and a mention about back drive efficiency (Eb) somewhere at http://www.roton.com/worms.jsp. I saw this from a random search, so don't take it as hard fact: "A rule of thumb for the worm drive is they wilt not back drive above a 20:1 ratio. If vibrations occur, however, the ratio will need to be higher. Self-locking in the gear pass depends on the coefficient of friction between the worm and the worm wheel, which depends on the choice of materials and the lead angle of the worm, which is a function of the desired ratio."
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 06-02-2004, 08:42
I will try to put this to bed so everyone is comfortable about the window motor and its ability to resist back driving. Two pieces of info:
1. Torque at breaker limit for window motor (torque when breaker starts to trip) ~ 5 N-m
2. Speed at which this occurs ~ 50 RPM
The max torque the window can put out is MUCH lower (at least 10 times) than the backdriving torque required to destroy the worm or break free. From experience, I can tell you that the worm breaks before the motor breaks free.
In theory, you could put a large enough diameter spool so that the 130 lbs of robot weight would break the motor, but then you would not be able to even lift yourself up. If you design the spool and motor combination to actually lift the robot up, then you are nowhere near back driving the motor.
-Paul
Unread 09-02-2004, 17:58
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
we used the window motors last year for our fold out pushing arms that weighed 5 lbs+ each. they were place and the bottoms of the arms. we had to reaplace them several times because the load stripped the gearbox.
Unread 09-02-2004, 18:13
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
This is brilliant. Pretty simple actually, but i didn't look at it that way. Thanks!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 09-02-2004, 18:30
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
aye, we also are using the window motors...a combination of 2 actually because we have the weight and we can...less strain on each motor and all...and after running some of the claculations, we can lift approximately 600 pounds with the motors in combination with gearing down the motors. So yeah...that eliminates the need what so ever to build a devise that prevents the motors from back driving and we really have no worries about breaking the worm gear, especially after some of the testimonials afore mentioned.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
What if FIRST changed back to 2 coaches? D.J. Fluck General Forum 45 08-01-2007 18:25
When do you (HS Students/College Students) go back to school? D.J. Fluck Chit-Chat 58 03-09-2002 12:14
What is it that brings you back each year?? Amy_ComBBAT General Forum 10 04-05-2002 16:31
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Taking the kits from Manchester on planes back to home base Ken Leung General Forum 4 24-09-2001 22:47
