Go to Post Javelins, armadillos, and rhubarb pie haven't been used as game pieces yet, either. Just sayin'. - Travis Hoffman [more]
Unread 22-02-2002, 18:06
Matt Reiland's Avatar
'The' drive behind the drive
Who here likes their control system in 1 piece?
From the pictures in the gallary there are a ton of designs with wiring and the whole control system in plain open sight? That thing costs over a $1000 to replace. Anyone with their controls wide open ought to be buying lexan right now. Even inadvertant hits with a robot, goal grabber, or ball grabber can cause catastophic failures to these components.
I think the warrany automatically expires if you bring it over to first with a hunk of aluminum through it.
Please teams, for your sake, armor up a little on your first practice day this equipment costs too much to waste.
Unread 22-02-2002, 18:11
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Ahh but armor weighs too much! Can't we just hit them harder then they hit us?
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 22-02-2002, 18:13
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
i totally agree. our wiring is pretty much exposed, and it could easily be inadvertantly torn apart by another bot. we're going to put a lexan shield around it ASAP before comps.
oh, that part abt the warranty. isn't it ironic that the label says "warranty automatically void if broken."? am i mistaken, or isn't that the purpose of the warranty, to replace it when it breaks?
Unread 22-02-2002, 18:39
tenthirtythree's Avatar
tenthirtythree tenthirtythree is offline
Eat. Sleep. Rescue. Repeat.
AKA: Damian "Chip" Eveland
FRC #1816 (The Green Machine)
tenthirtythree is an unknown quantity at this point
Ugh...if only it were that simple...
Stephanie, warranties are designed to have loopholes --- yep, quite ironic.
Our wiring is actually pretty protected, but we're adding some "battle armor" just in case.
Thanks, Matt, for the extra "sense of urgency."
#171 - Platteville, Wisconsin
Unread 22-02-2002, 19:37
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Lol - Yea, the warrenty basically means "If it breaks and you try to fix it yourself, then the warrenty is void" ... not that they word it like that at all!
Our wiring and stuff is sheilded by our oh-so-reliable polycarb siding =) Nothing will be touching that - unless we want it to be touched!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 22-02-2002, 21:34
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
this isn't talking about if another robot smashes into you and destroys the piece. under that sticker is a screw, and to take the unit apart, you must unsrcew that screw. but, if you take it apart, you might break it, so therefore, if you remove the sticker to look at the insides, you void the warrenty. believe me, we had this conversation one of those late nights.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 22-02-2002, 22:16
hehe i believe it actually reads "Warranty void if broken"
The trick is to have them fix it BEFORE it breaks, it'll save you lots of money.
Unread 26-02-2002, 18:56
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
Armored control systems
I don't know about a lot of teams, but armor for our control system was a high order priority.
Our control system is mounted to reenforced plexi and is covered by a 1/4 inch thick plate aluminum shell.
I'm relatively sure it'll bouce small caliber pistol hits.
our control system is also quick detachable, so that if it does break, we can sweep out the pieces and replace it with a backup.
I think it works well.
If you want to see it, feel free to stop by our pit at either the LA or SJ regionals.
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Unread 28-02-2002, 15:24
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
You guys have to remember that trhe control visible HAS to be easily visible for refs. This doesn't mean you don't protect them, but you've gotta be able to see it. As long as it's mounted and not right against the side, you should be fine...
~Adam
Unread 01-03-2002, 07:37
junkyarddawg junkyarddawg is offline
junkyarddawg is an unknown quantity at this point
on the money
Matt:
Right on the money, We even mounted are speed controllers on a piece of lexan and each end of the lexan is suspended in a half inch of foam in five directions. The fans on the speed controllers cannot take alot of abuse. We were going to mount our controller in the same fashion and just flat ran out of time, but we do have a .25" piece of lexan in front of our controller. I think the components most vulnerable to shock on the robot controller are the plug-ins, such as fuses, cable ect...
It might behoove everyone to add tape or something to keep fuses and cables from falling out from vibration.
Tim Gates
Team #288
RoboDawgs
Unread 01-03-2002, 07:40
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
If your fuses are coming out from shocks or vibrations, I think that you're going to have bigger troubles than missing fuses. I can't speak for your bot, but I know that ours are fairly difficult to pull out by hand. PWMs on the control board though, those can be a pain. We had our right drive train fall out during a match at VCU last year.
~Tom Fairchild~
Unread 01-03-2002, 07:41
and...
Matt:
My apologies for not including this in the post. We did use rubber shock mounts to mount our Robot Controller to the bot. Not the best, but it is something that other teams can do if they have at least a half inch to give in front of thier controller. And this can be done in 15-45 minutes at the competition. They are considered a fastner and small parts sell them as well, or use the ones that came with your air compressor.
JunkYardDawg
Unread 01-03-2002, 07:54
ounce of prevention
Tom:
We are not having any trouble, but an ounce of prevention is worth a pound of cure. And it breaks my heart to see teams that are struggling already have to struggle with a myriad of nuances that could have been prevented. Also, our controller is mounted vertically and facing the direction that the bot travels. Most people would not have quessed that the lever on the 60 amp breaker had enough inertia to switch states when the bot collided with another bot, but it did.
Good Luck:
Tim Gates
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
