Go to Post I decided I would keep coming and it just kept getting more and more fun. By the time build season started going I couldn't have quit if I wanted to ^_^ - Mr. Pockets [more]
Unread 04-02-2004, 18:59
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Question Gear Help Needed- Urgent
I'm supposed to be ordering gears for a gearbox my team needs (not for the drive train) and I’m trying to find Aluminum gears, or something lighter than steel. Any idea on where I could find such a thing? Also, I’ve noticed some are made of Acetal, what is it and would you consider using them?
Team 241
Unread 04-02-2004, 19:35
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Re: Gear Help Needed- Urgent
mcmaster.com
smallparts has em too
Unread 04-02-2004, 21:11
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
You can also try MSC (www.mscdirect.com). We deal with them and they are very good, and in most cases you get your order the next day. From what I've been told acetal is a type of plastic. I've also seen nylon gears. I'm not sure of what you're doing with them but just make sure that they're strong enough (hold up) for what you're going to do.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 04-02-2004, 22:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I concur. Make very certain that the gears will be strong enough. Aluminum might be strong enough for what you're trying to do, but you might want to make some calculations first. If it's not strong enough you'll strip gear teeth really quickly.
Here's a link to Martin Sprockets with everything you should need to figure out the allowable torque for a gear.
Martin Sprockets
Unread 05-02-2004, 00:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
www.wmberg.com
Unread 05-02-2004, 01:32
REVving up for a new season
FRC #2848 (All-sparks)
materials for gears:
steel- used for high tourqe high speed operations
aluminum - used for less strain all around use
plastics - used for low power and general opperation many for wet enviorments
in most places you can buy gears there are strenth/ speed ratings check those vs the opperation they are for before buying
Unread 05-02-2004, 13:44
Technical Manager
Team Role: Driver
Talking Re: Gear Help Needed- Urgent
Thanks for the quick response, you helped a lot
Team 241
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
