Go to Post Robot shoots forward across field and jams itself into opposing alliance bridge. It was, however, the fastest our robot ever went. - PandaHatMan [more]
Unread 05-02-2004, 17:55
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Analog in on OI: Heads Up!
Originally Posted by Dave Flowerday
You're only allowed to use 100K ohm pots on the OI inputs. Check the OI Reference Guide page 5. There's a good reason for this, and it's related to the the fact that there's a pulldown internally inside the OI (to force the 127 condition when the joystick is unplugged).
It sounds like your setup looks like this:
         15k                   15k
+5v ---/\/\/\/\------+-------/\/\/\/\----- +5v
                    \ 560 ohm
                  Gnd
If this is the case, check the wiring diagram again on Page 5. This isn't the right way to connect to the analog inputs.
Thanks it's a case of Re RTM
Allegro ACS750 Current Sensor 150uF Heads Up Dale(294engr] General Forum 0 04-02-2004 21:14
OI and analog: Zero value Astronouth7303 Programming 1 02-02-2004 16:00
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Bouncing heads.... archiver 2001 2 24-06-2002 00:14
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
