Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 05-02-2004, 18:38
PsiMatt's Avatar
PsiMatt PsiMatt is offline
Supreme Mage of the Light
AKA: Matt Lee
no team (Schmobotics)
PsiMatt is on a distinguished road
Send a message via ICQ to PsiMatt Send a message via AIM to PsiMatt Send a message via MSN to PsiMatt Send a message via Yahoo to PsiMatt
Exclamation A Question of Interpretation
Say one was manuvering a robot into opponent territory, and opponents decided to target one's robot (or large ball being held by robot, or the area around it) with their small balls. Would that be considered goaltending?
For efficiency's sake, please limit your replies to an answer that addresses the question, and explanation of that answer. I'm sure the moderators are tired of seeing debates about the nature of FIRST come up in these threads, and i'd appreciate it if the answer i recieved was to the point.
Founding Member, Team #1135
Supreme Leader, Team #1135
Rookie All-Star 2003
Matt, PsiGuardian of the Light
Lil' Schmoe of WHS Schmobotics
most feared phrase: "MATT...something went wrong...!"
Unread 05-02-2004, 21:27
hcperdan hcperdan is offline
#0135 (Penn Robotics)
hcperdan is on a distinguished road
Re: A Question of Interpretation of goaltending
Goaltending is specifically defined as interfering with a small ball on its downward flight toward or within a goal. If they start heaving balls at your robot and it is not between them and the goal on the downward path of the balls, no problem. It's not goaltending.
I can foresee issues if the HPs start targeting a robot in the process of capping a goal. However, I doubt if they will nail you if you get in the way of your own HPs. And, if you are capping the opposing alliance's goal for them, you merely cease capping their goal for them since the small balls with which they are targeting you will have been given double points (which is why you were capping their goal for them in the first place).
I'm a PHYSICIST, not an engineer.
Step by step walk the thousand mile path.
Unread 05-02-2004, 21:32
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I think the below is from the NBA definition
Goaltending -
Goaltending is a violation where a defender tries to BLOCK the ball from going into the BASKET, but the ball was on it's way down. It can also mean interferring with the ball when it's on the rim of the BASKET. If goal tending is called against the defensive team, then the offensive team automatically gets the points for the SHOT, regardless if it would go in or not. But when goaltending is called on the offensive team, the shot doesn't count and the other team gets to inbound the ball.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 05-02-2004, 21:33
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
If the judges decided that a ball had a resonable chance to go into the goal but it hit your robot/big ball being carried/capping, then penatly.
If the ball wasn't headed in, then no penalty.
Wetzel
Judges decisions are final.
Thank them for volunteering several long days.
Unread 05-02-2004, 21:36
PsiMatt's Avatar
AKA: Matt Lee
Danke
A question about control system options computhief263 Control System 7 04-02-2004 14:46
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
New FIRST Ruling -Wow the implications Mike Martus General Forum 51 07-02-2002 22:03
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
