Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 05-02-2004, 22:13
Burgabot Burgabot is offline
#1067 (Junior Billikens)
Burgabot is an unknown quantity at this point
Does anyone know anything about these things?
Well, I was hoping that some of you could help me on this one. Something that would be very useful on our bot this year would be something like what I drew up and attached to this post (please forgive the rough sketch, I just drew it in Paint). It is something like the commutator of a motor, in that it uses brushes to transmit current on a rotating cylinder. You'd connect wires to both ends, and you'd be able to turn one end freely without worrying about twisting the wire. The rings are concentric circles so that many wires could be connected. If anyone knows what this is called or where to get one, it would be greatly appreciated. Thanks!
Unread 05-02-2004, 22:22
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: Does anyone know anything about these things?
Check out this thread about Slip Rings:
http://www.chiefdelphi.com/forums/sh...ight=slip+ring
Unread 05-02-2004, 22:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
They're apparently called slip rings. There's a thread about them here:
I believe the conclusion was that it was probably legal to use.
Unread 06-02-2004, 07:45
Burgabot,
Nice idea! Yes they are called slip rings and FIRST has ruled that they are acceptable this year if they fit the flowchart and they must be included in the robot inventory price limits. They are very expensive pre made but I expect some teams to come up with homemade alternatives. BTW, your car alternator uses slip rings to supply current to the field coil. I am waiting to see if someone adapts a part of an alternator for use on their robot.
Qotw [01-05-03]: top 5 things in your mind... Ken Leung Rumor Mill 37 13-02-2003 00:45
a few minor things... Brandon Martus Announcements 0 03-01-2003 23:39
A hint of things to come... archiver 2001 0 24-06-2002 01:12
A few things RebAl CD Forum Support 2 18-04-2002 18:34
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
