Need help with Sensor
When we power the detector with 5V and ground and look at the voltage of the output from the detector out, that is the output is not connected to the RC, just the meter, we seem to detect a change from 5 V when there is no signal from the beacon and 4.4V when there is a signal. Is this right? Can someone explain what is going on?
Re: Need help with Sensor
I believe the IR recievers are setup to output a low voltage as positive confirmation of a signal. This means with no IR signal, it will output 5 volts. When there is and IR signal, it will output a lower voltage (ideally 3.3v I believe, as per the spec sheet of these sensors).
If your sensors are outputting a lower voltage with no signal, it could mean a number of things- damaged recievers, IR noise/reflection, unstable input voltage, or something of the like. |
Actually the spec sheet says that the maximum output voltage when it sees a signal is 250mv. That being said, if you are just using a simply volt meter, you will most likely not see anything near 0v, but some other voltage (Possibly around 4.5v for the type 0 beacon since it is only on for 10% of the time. Beacon 1 would be slightly slighty lower, say 4v due to it's 20% duty cycle)) Exactly what may vary from that though, depending on your meter. |
-Kevin Last edited by Kevin Watson : 06-02-2004 at 01:33. Reason: Icky spelling error. |
Whoops, my mistake. I guess that's what I get for reading spec sheets late at night I think we saw our recievers outputting 3.3v, but that was before we found a couple of things wrong with the beacon. Now we are indeed seeing 4.5v with the type 0, and 4.0 with the type 1. Thank you Kevin, for all the work you've done! |
Thanx everyone for ur help/input!
| IR sensor trouble | D.Viddy | Electrical | 2 | 30-01-2004 09:49 |
| Warning: Error in infrared sensor construction document | Kevin Watson | Electrical | 1 | 29-01-2004 19:28 |
| Reflective tape sensor? | scitobor 617 | Electrical | 2 | 19-11-2003 08:51 |
| sensor doesn't work | PBoss | Programming | 7 | 29-01-2003 18:39 |
| How do you connect optical sensor? | archiver | 2001 | 1 | 23-06-2002 23:05 |
