Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 05-02-2004, 22:39
Hop_of_752 Hop_of_752 is offline
#0752 (Knights of Fury)
Hop_of_752 is an unknown quantity at this point
Send a message via AIM to Hop_of_752
Need help with Sensor
When we power the detector with 5V and ground and look at the voltage of the output from the detector out, that is the output is not connected to the RC, just the meter, we seem to detect a change from 5 V when there is no signal from the beacon and 4.4V when there is a signal. Is this right? Can someone explain what is going on?
Unread 05-02-2004, 23:58
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Need help with Sensor
I believe the IR recievers are setup to output a low voltage as positive confirmation of a signal. This means with no IR signal, it will output 5 volts. When there is and IR signal, it will output a lower voltage (ideally 3.3v I believe, as per the spec sheet of these sensors).
If your sensors are outputting a lower voltage with no signal, it could mean a number of things- damaged recievers, IR noise/reflection, unstable input voltage, or something of the like.
Unread 06-02-2004, 01:02
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Actually the spec sheet says that the maximum output voltage when it sees a signal is 250mv.
That being said, if you are just using a simply volt meter, you will most likely not see anything near 0v, but some other voltage (Possibly around 4.5v for the type 0 beacon since it is only on for 10% of the time. Beacon 1 would be slightly slighty lower, say 4v due to it's 20% duty cycle)) Exactly what may vary from that though, depending on your meter.
Unread 06-02-2004, 01:11
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Hey, this is very cool because this is exactly what you should be seeing. With the beacon present, the meter is averaging the the output of the sensor over time. An ideal meter when measuring a +5 volt pulse train will register a voltage equal to 5 * (on time/total time). The output of the sensor, when viewing the type-0 beacon, is on for 9.0ms of every 10ms. plugging this in to the equation results in a voltage of 4.5. On the other hand, the output of the sensor, when viewing the type-1 beacon, is on for 8.0ms of every 10ms. plugging this in to the equation results in a voltage of 4.0. I'll bet your sensor was pointed at the type-0 beacon when you measured your 4.4 volts. If both beacons are in view of the sensor, the voltage will be even lower (3.5v). You can find an illustration of the sensor output here.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-02-2004, 18:31
I fix stuff.
AKA: βetamarc
Whoops, my mistake. I guess that's what I get for reading spec sheets late at night
I think we saw our recievers outputting 3.3v, but that was before we found a couple of things wrong with the beacon. Now we are indeed seeing 4.5v with the type 0, and 4.0 with the type 1. Thank you Kevin, for all the work you've done!
Unread 06-02-2004, 23:43
Thanx everyone for ur help/input!
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
Reflective tape sensor? scitobor 617 Electrical 2 19-11-2003 08:51
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
