Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 05-02-2004, 07:23
Re: Maxi 40 Amp Fuse Panel
Originally Posted by Joe Johnson
Are you sure that the part number they gave is the "functional equivalent" of the parts in the kit?
Now I am curious, I will stop by on my way up to work on the robot tonight.
Stay tuned.
Joe J.
Joe, Inquiring minds want to know...what do they look like and how heavy are they?
Unread 05-02-2004, 09:23
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Looks Like Stingers are legal
Well, this was posted in the Q+A...
Q: Update 04 gave Terminal Supply as an alternate for the Maxi Fuse Block. TS said that the Maxi Fuse Block JEF-531-D is on back order. Is there an alternate for the alternate?
A: If you are looking for a spare, Terminal Supply should have more by the time our regional events begin. There are other distributors, such as Stinger Electronics (www.stingerelectronics.com) that may be able to direct you to your nearest retailer.
So, it looks like the stinger fuse holders are OK to use.
Unread 05-02-2004, 11:14
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The woman (Carrie) who I was supposed to talk with was not in the office. The people who were in were not knowledgeable.
What I DID find out is that the part is not a standard part from Terminal Supply, it is a special part number for FIRST.
Just spoke to Carrie: They are working to find another part.
Give them about about a half day or so, they sounded like they'd have something in place.
Joe J.
Unread 05-02-2004, 22:41
AKA: Dr. Joe
FRC #0088 (TJ2)
Some sources
From a google search for "Stinger SFB1MAX"
http://autosoundgear.com/tek9.asp?pg...cific=joenrnp4
http://www.darvex.com/miva/merchant.mv?Screen=PROD&Product_Code=SFB1MAX&Categ ory_Code=FH
http://www.hifisoundconnection.com/b...=52&product=id
http://www.audiooutfitter.com/store/...l/SFB1MAX.html
http://www.sounddomain.com/sku/STISFB1MAX
I hope this helps.
Joe J.
Unread 06-02-2004, 07:25
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
Originally Posted by Matthew_H
I believe that that would not be leagal. We are still waiting for our replacment Maxi 40amp Fuse Panel. I am hoping it will be in tommorrow since FIRST said all Critical parts should be delivered to us by the 2/4/04. Has any other team recieved thier replacement.
we got it... about a week ago, and now with more parts that came we actualy got another one... sorta weird.. but now we dont have to buy a replacement if it breaks
Nick .R. (Team 1009)
Unread 06-02-2004, 07:30
Re: Some sources
Joe J.
I actually like these better since they have a common power input, but FIRST wants the four independent slots with the transition block. I like the transition block too since it gives a nice place to tie return wires. Too bad the stuff weighs so much.
Unread 06-02-2004, 07:32
Nick R.'s Avatar
Re: Some sources
we dont have a prob with weight... our robto last year was... 81 pounds..it was a joke..lol this year we're going for 110lbs it will work better... hopefully
Unread 06-02-2004, 07:53
Re: Some sources
Nick, I sometimes envy teams who start out under weight and then have a chance to grow. We start out over and start stripping and drilling to make weight. Last year at nationals, 130.00, whew! Good thing it wasn't too humid.
Unread 06-02-2004, 11:18
quickie25's Avatar
quickie25 quickie25 is offline
quickie25 is an unknown quantity at this point
We also did not recieve ours. We went to our local auto parts store for a functional replacement with the same amperage, $7.95
Is this legal? We could not wait any longer for it to come in..we had to proceed with testing..
alloy - a mixture containing two or more elements fused together...(ie. A Team)
Unread 13-02-2004, 15:00
nosam89 nosam89 is offline
nosam89 is an unknown quantity at this point
Yeah i put my maxi 40 amp fuse panel on my lawn mower...
WOO HOO I ROCK AND ALL OF YOU...
MUHAHAHAHAHAHA
Unread 13-02-2004, 15:19
darknight darknight is offline
Junior Member
#6666
darknight has a little shameless behaviour in the past
Originally Posted by mtrawls
Our team did not receive the Maxi 40 Amp Fuse panel in our KOP -- we mistakenly got 2 of the low amp fuse panels. We contacted FIRST, but haven't yet received a response, and, as it is somewhat important to move forward, have purchased one elsewhere. (It is brass and very heavy .) Anyway, each fuse accept a different input power source, and we have to, therefore, split the power coming from the 6 AWG wire from the fuse breaker into 4 to power it. I just wanted to make sure all this is legal, i.e., using a different fuse panel than that provided in the kit (granted that none was provided in ours). I didn't see anything immediately applicable from a glance at the electronics/wiring section. Thank you.
i's is originally from kentucky and in ken tuc key we's be's racin' the law on ir' vakums and i bout the maxi foty amp foose panel and poot it on mi vacoom cleaner it nao do's sevety threi mailes uh hour it be a red'naeck ride yo'
G-unit in da heisey
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Maxi Block Confusion? Adam Shapiro Electrical 11 26-01-2003 20:23
What else do we want? archiver 2000 63 23-06-2002 23:19
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
