Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Unread 05-02-2004, 16:06
LittleProton's Avatar
LittleProton LittleProton is offline
Skinflute Player
AKA: Joe Gannon
#1388 (Eagle Robotics)
LittleProton is an unknown quantity at this point
Burning IR sensors
The IR sensors provided with the kit of parts seem to fry easily. So far the only heat I’ve applied to the sensors is soldering and the +5v from the controller. Is this a problem for any other teams? Any advice/help would be appreciated.
"The best thing about that is, I wanted it to happen and then it did!" Black Mage
8BTH
Unread 05-02-2004, 16:10
Re: Burning IR sensors
You might check this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=24773
Unread 05-02-2004, 16:54
Are you attaching a heat sink between the soldering and the chip?
We lost one to soldering that way when a student tried it before being instructed in soldering techniques.
Unread 05-02-2004, 20:06
Skinflute Player
AKA: Joe Gannon
No, I did not attach a heat sink to the sensors, but instead of soldering on wires to the pins we did our own circuit board to reverse the positive voltage and ground voltage supply. (If i'm not mistaken that would require less heat)
I am fairly certain that the problem is not with the soldering. We had a fully functional prototype, but now, after lots of test, it's not functional. So my question is about hooking these sensors directly to 5V.
8BTH
Unread 06-02-2004, 07:55
Remember that there was an error in the early docs that had the FET in backward.
Unread 06-02-2004, 09:02
We originally hooked all the IR sensors up directly to the 5v supply from the controller to check them out and have been running them for a few weeks on the interrupt 5v and haven't encountered any problems.
We have burned them out by shorting them, hooking them up incorrectly, using a soldering iron > 20watts w/o a heat sink, etc. That's why we purchased spares for the students to practic on. (They've (and mentors) have gotten much better.
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
