Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 05-02-2004, 22:09
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Dynaminc Braking on Victors
I understand that one can short A and B on the jumper on the Victor to put it in "dynamic braking mode" As i have been told, this will have the speed control give enough power to the motor to prevent it from being backdriven. I have a couple of questions about this.
1. Does this affect normal speed controlling of the motor?
2. Does it work effectively in both directions of backdriving?
3. Is there a way to estimate about how much power it will draw to keep it still?
4. Will it be effective for a winch, as in will it have a quick enough response time to not let the winch slip too much before holding?
Thanks.
Team 1257
Unread 05-02-2004, 22:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Dynaminc Braking on Victors
dynamic braking will NOT stop backdriving. This has been conclusively proven many times. Dynamic braking doesn't apply any power to the motor at all. It simply makes the motor more difficult to turn if you aren't already applying a voltage to it.
The way it works is that it shorts the leads of the motors together when the Victor isn't applying power to the motor. This creates back-EMF when the motor is spinning, but does absolutely nothing while the motor is at rest. Try it with a drill motor or CIM. Spin it by hand when the wires aren't connected, then have someone hold them together and see if it's harder to turn it.
to answer point by point:
1. No, it will not affect the normal operation in the slightest, though if you use it on drive motors, your robot will stop MUCH more quickly as opposed to coasting.
2. Yes, it work in both directions, but doesn't stop backdriving.
3. It draws ZERO power.
4. No, it will not stop your winch from slowly unspooling at the end of a match, AT ALL.
Unread 06-02-2004, 08:26
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
By itself, it may not stop a winch from unwinding itself, but if you use a Victor set in Brake mode along with a motor with a worm gear (Van Door motor, perhaps?) then it would be pretty hard to unspool itself (although not impossible).
We've done some testing with the brake mode on drive motors, and it makes the robot stop much faster than in coast, so it definitely has an effect, if the motor is spinning at high speeds. But anyone who knows the fun hand rules from physics can figure that out .
AIM --> Woloi
Email --> ian@woloschin.com
Unread 06-02-2004, 09:36
We tried van door + winch + braking on the 2000 chin-up bar. It didn't work terribly well and we had it geared down rather low. I'm not sure that there are any motors in the kit that don't backdrive, but that's a discussion that's already happened in atleast one thread this year.
Unread 06-02-2004, 12:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Are you saying the van door motor IS backdriveable?
Unread 06-02-2004, 13:33
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Yes, the van door is backdriveable, and fairly easily too. Try it yourself. It only takes maybe 30 in-lb or so to backdrive it.
/* Daniel */
Unread 06-02-2004, 13:41
oh yeah. heck, van door motors are backdriveable by design. How else do you open a van door if the switch breaks or something?
Just because it's a worm drive doesn't mean it's not backdriveable by default. Take a look at what Martin Sprockets has to say:
Martin Sprockets
That being said, I only know that previous year's van door motors were backdriveable. That might not be true this year. I'll clamp one down tomorrow and go at it with a cresent wrench.
Unread 06-02-2004, 13:43
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Our 2000 van door motor winch would backdrive without power with a 130 lb. robot on it. Think about how a boat winch and it is an easy problem to solve
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
victors great_one411 Electrical 4 06-02-2003 09:08
Flakey Victors archiver 1999 4 23-06-2002 21:58
Victor braking feature MattB703 Electrical 12 21-06-2002 07:26
What subtitutes controllers, radios, Victors and Spikes? Digo Technical Discussion 6 15-05-2002 16:04
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
