Go to Post You're here for them, not for you. - Chris is me [more]
Unread 19-01-2004, 16:22
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Palm OS Dashboard PRGM
Ok, let me begin by saying that i have searched for this, and found only discussion.
Is there anyone out there who has a working dashboard program for palm os?
Thanks
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 19-01-2004, 16:24
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Palm OS Dashboard PRGM
Great Idea. But unless you have a VB compiler for PalmOS, then your out of luck (Like anyone has the time anyway!)
Unread 19-01-2004, 18:32
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
not necessarily - a dashboard doesn't have to be written in vb, it just needs to be able to accept serial input, which is perfectly possible for the palm (its sync port is a serial port).
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 20-01-2004, 07:27
AKA: Jamie Bliss
I ment that's all I do.
Unread 01-02-2004, 03:28
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Once we all get familiar with C, there's a neat (read "free") little compiler for the Palm OS called "Pocket C" that might be usefull for writing a dashboard utility.
Unread 01-02-2004, 04:14
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
I have a palm program written in C that gets data from the dashboard port then prints it to the screen. It will be a dashboard program eventually I just haven't finished it yet. I will probably finish it after the robot ships.
I'm also working on wiring an LCD to the dashboard port. Right now I have it working with the RC, but it will be more work to actually get it hooked up to the dashboard.
Unread 01-02-2004, 10:53
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I've done some Palm development before. The actual program coding isn't very hard as the API is pretty straight forward but I have no idea about the serial access. I imagine it would be much harder than coding for the GUI. You might want to search in the developers section of palm.com or on google (you need to sign up, I believe, for palm.com but it is free).
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 04-02-2004, 23:19
rdsideresistanc's Avatar
rdsideresistanc rdsideresistanc is offline
AKA: Joel F
#0825 (SWVGS Maximus)
rdsideresistanc is an unknown quantity at this point
do palms use windows CE? I have eMbedded Visual C++....which develops applications for windows CE...i could pretty easily port a dashboard program i would think, since all this stuff is .NET now....
Unread 05-02-2004, 00:27
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Palm-based devices use PalmOS. The OS architecture of PalmOS is very different from that of Windows, and a port would probably be more difficult than simply cross-compiling your WinCE code after modifying a few libraries. I have played with Pocket C in the past, and found it to be quite powerful; it might be wise to use the official Palm SDK for more complex operations like serial port I/O, although that necessitates finding a compiler to use with it.
Unread 05-02-2004, 00:34
AKA: Joel F
i was kind of thinking they were completely different...oh well.
Unread 05-02-2004, 16:09
By the way, serial access in Palm, like many other OSes, is actually quite simple. It's just like reading a file in windows. You just call a get function (can't remember the exact syntax right now) and tell it how many bytes you want to get. You can also check how many bytes are in the buffer and many other useful functions.
The hardest part about Palm programming is how anal it is about memory management. If you leak any memory or use a pointer where you should use a handle there is a good chance you will hit a fatal error.
Unread 05-02-2004, 22:22
Ferazel2001 Ferazel2001 is offline
Mac Junkie
AKA: Devon
None #0599 (Robodox)
Ferazel2001 is on a distinguished road
Send a message via AIM to Ferazel2001 Send a message via MSN to Ferazel2001 Send a message via Yahoo to Ferazel2001
Lightbulb Re: Palm OS Dashboard PRGM
Well, I am seriously the 83+SE nerd, so I will attempt to write a program using the get( function... is there any way to get the data from the 9pin to a TI cable? like can someone w/ more electrical knowlege make something that inputs from a 9pin, and then passes each line one by one through the cable? if you could post the schematics for that, it MAY be possible. MAY MAY MAY.
-Devon
Unread 06-02-2004, 00:35
#0246 (Overclocked)
Use one of the older RS-232 TI GraphLink cables with a 9-pin null modem adapter. I don't know if TI still makes them, but if not, there's always eBay.
Being something of a TI fanatic myself, I have to say that your idea is absolutely brilliant. The TI-83's built-in facilities for graphing data would be absolutely superb for monitoring a robot's behavior, and the simple programming interface (in TI-BASIC, anyway) would be ideal for quickly creating a working dashboard program.
Unread 06-02-2004, 13:24
AKA: Joel F
I actually have one of those old serial port TI-Graphlink cables.....I might actually try this myself. Thanks for the idea!
Unread 06-02-2004, 13:43
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
For those of you interested in programming for PalmOS, there is a free compiler called PRC-Tools (which is based on GCC) which can compile palm programs from C or C++ source. You can get it from http://www.palmos.com/dev/tools/gcc/.
There are IDEs available (such as CodeWarrior for Palm), but none for free yet. However, PalmSource (the makers of PalmOS) have announced that they will release a free IDE (based on Eclipse) for compiling Palm programs at the Developer Conference next week.
Zan Hecht
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
How About A Palm Dashboard Program? archiver 2001 0 24-06-2002 00:52
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Palm Dashboard Software Neal Probert General Forum 4 06-05-2002 14:16
Scouting/Scoring System for Palm M3 A. Leese Scouting 12 24-07-2001 23:31
