Go to Post Good programmers always find a better way to do something, especially when it's not obvious where those improvements can be found. - Mr. Lim [more]
Unread 05-02-2004, 20:03
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Software SPI Interface
I have been trying to interface a sensor that uses an SPI interface to the RC. I know the actual SPI bus on the PICs is used by IFI - this is how the two PICs communicate. However, C18 has a set of "Software SPI" functions that use digital input pins to emulate SPI (C18 Library Manual, p.121).
I looked at the default values for the SPI pins in the manual. They appear to correspond to digital inputs 1, 2, 5, and 6 on the RC. I connected the sensor to these pins, included the sw_spi.h header in the project, and tried to talk to the sensor.
For some reason I cannot get the data out of the sensor. I either get all 1, or all 0 in a byte No real data.
I am suspecting a conflict with the default FIRST code. The function that initializes the SPI, OpenSWSPI, is supposed to set up the pins correctly. Could it be that the FIRST library is conflicting with this? I tried to remove all lines that referenced the pins I am using from the default code. Didnt help.
Also for some reason if I change the pin assignment in sw_spi.h in the mcc18 folder the program does not build properly. Do I have to recompile something or include any other files in my project?
Did anyone use the software SPI functions? Or the software I2C which should be close to what I am doing?
Unread 06-02-2004, 15:09
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Software SPI Interface
I have no idea what SPI is, but I'll try to give you some general pointers passed on your message.
Is there any docs on using SPI and how to connect a SPI sensor?
Is the hardware wired for this?
Did you check for semi-colons and the like? One of my probs
Did you wire the sensor wrong?
Is the sensor bad?
Where is the Actual code for the functions? if it is in a lib, I wouldn't mess with it at this time (get it to work first, then check Editing Main.c for advanced stuff)
Could it be that it's working, but not as you expected?
Are aliens skrewing around with it wile your not looking?
Unread 06-02-2004, 15:21
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by Astronouth7303
I have no idea what SPI is.
SPI? I haven't the faintest either. Could you clarify that for both of us?
Or the gremlins that hide under carpet. They always get us.
Unread 06-02-2004, 15:38
AKA: Jamie Bliss
Where? Google? What does it stand for?
[edit]I went to Google. You know how many things SPI stands for?!?!?!?!?!?!?[/edit]
[edit]Is SPI a company, or a format? Or both?[/edit]
[edit]Think I have it. http://www.mct.net/faq/spi.html
Well, it ain't ours! They're under lock and key, I think...
Unread 06-02-2004, 15:48
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
serial peripheral interface. Don't know how to interface it though.
Unread 06-02-2004, 15:50
For those who are wondering what SPI is: http://www.mct.net/faq/spi.html
Sorry, I don't have any experience with SPI on a PIC.
Unread 06-02-2004, 15:56
AKA: Jamie Bliss
Thank you for conferming my find. I just read through it, And it sounds pretty nifty. Tell us how you figure it out.
Unread 08-02-2004, 13:27
Greg's Avatar
I have another question. Which PIC controls the digital IO pins on the robot controller - master or the user PIC? In other words, is it possible to update data on those pins without calling Putdata? Or does it only update the state of the digital outouts when putdata is called?
Unread 08-02-2004, 13:39
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
The Digital I/O pins are all controlled by the User Controller (Putdata() is not required.)
Unread 08-02-2004, 17:40
Umm Errr...
If you want some help your going to have to post some code, what sensor your are using and to what pins it is wired.
1139 Alumni
Unread 08-02-2004, 20:27
Kevin Casper Kevin Casper is offline
#0171 (Hardcore Engineers)
Kevin Casper is an unknown quantity at this point
I have never used the c compiler SPI functions, but I have done firmware Serial Port Interface in assembly on a pic16 series processor. I used it to connect to a digital pot. Depending on what you are doing, my advice is to simply write the software explicitly. SPI is a very simple protocol. The meat of spi is between clock and data pin. Check whatever you are connecting to, if it reads the data pin when your clock pin equals 1, the rise of the clock or cycle, then set what the next bit is when you toggle the clock to 0. Toggle the clock pin 16 times, 8 toggles to value 0 and 8 to value 1, to transmit a byte.
Make a function to do a byte at a time. It shouldn't take more than a half hour to set this up. Most intermediate programmers can do it in several minutes for simpler SPI interfaces.
There is normally a select pin to indicate when the device is reading. Bring that low, set it to zero, for the duration of the communication. Assuming I didn't forget anything critical, it's been a while, that should all there is to most SPI communications.
Kevin Casper
Unread 08-02-2004, 21:38
Greg's Avatar
Thats exactly what I am planning to do now - write my own functions It would have been nice to get the pre-written ones working (they should be doing the same thing anyway), but writing my own should not be hard. I'll give it a try in a couple of days (as soon as I finish some school assignments )and see how it works out.
how to create custom interface _GP_ Technical Discussion 1 18-01-2004 21:24
which software Ryan Foley 3D Animation and Competition 5 01-03-2003 23:39
Looking for operator interface... Where is it? mike325 General Forum 2 07-01-2003 15:28
Gyro interface to software archiver 2001 1 24-06-2002 02:51
software software software archiver 2001 5 24-06-2002 00:21
