Go to Post Fame is a funny thing, you can do nothing and get it, and do everything and get none. For me, it's not fame, but infamy that follows me. - Joe Matt [more]
Unread 06-02-2004, 18:03
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: 66 needs your help!
The real key, if using 4 wheel drive, is to have a pair of high traction wheels closest to the center of gravity, and a pair of lot traction wheels on the other side.
For example, you can turn down your skyway wheels on a lathe, one pair just until the first layer of plastic shows, and the other pair 1/8" or so beyond that. Then epoxy and screw a thin strip of incline conveyor belt material (very high friction) to the smaller pair. You should now have two pairs of wheels, about the same size, with vastly different amounts of grip. This solution was used by 992 when I was on it in 2002, and by 190 in 2003 (although we originally had conveyor belting on our front wheels, but it came off in competition). Both bots also had a very short length and a wide wheelbase, which helped.
On the other hand, 190's current robot is very long with a narrow wheelbase, and all our tires our pneumatic. Needless to say, turning won't be a major part of our strategy this year.
Zan Hecht
Unread 06-02-2004, 19:20
Dick Linn's Avatar
no team (Synergy)
Last season, we used 2 of the pneumatic Skyway wheels on one end, then a pair of the poly wheels on the other (8.75 or so inch diameter). Since the poly wheels were not the exact diameter of the rubber wheels, we "turned them down" by holding them between our knees and using a belt sander and a bit of elbow grease (not to mention finesse) to get them even and slightly radiused in the axial direction. Talk about a mess of black dust! Glad we did it at my employer's shop and not at school
Because we were climbing a steel mesh that year, we re-grooved the original channels across the tire using a 1/4 inch rat-tail wood file. The result was a bot that could climb the wire ramp (with a 110 lb. person on board) but still manage to turn, since the poly wheels were just a bit more slippery than the rubber ones. The axial grooves bit into the mesh on the way up to provide traction. This year the best way depends on your method of attacking the platform and whether or not you see it as a pushing/pulling contest.
As to turning and handling, you either play around with the geometry, center of gravity and traction, or gear it down to be a real brute to get the desired results. Adjusting for handling can be both a science and an art. At this point in the build, I think it depends on how much time you have left. Quickly try it on a different surface to see if things change dramatically. You might discover something.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 06-02-2004, 19:42
we "turned them down" by holding them between our knees and using a belt sander...
if I saw you doing that I would have spleened you with a spork!
