Go to Post In real life, I use almost nothing I learned from football except that with a bit of hard work you can get somewhere. Oh, and I have bad knees on top of that. I could have (and wished I would have) learned that from a FIRST FRC team instead. - JesseK [more]
Unread 06-02-2004, 19:05
m0rph3us's Avatar
m0rph3us m0rph3us is offline
AKA: Andre
#0293 (Spike)
m0rph3us will become famous soon enough
Send a message via ICQ to m0rph3us Send a message via AIM to m0rph3us Send a message via MSN to m0rph3us Send a message via Yahoo to m0rph3us
Question ADXRS150/300 Sensor
We are attempting to use the Analog Devices ADXRS300 Gyro. The wiring is mostly is already done in the Evaluation Board but we are having trouble knowing what pins to connect to the Analog Input.
In a previous post it seemed that we could hook up the entire evaluation board to the analog input from the controller interface.
Andre
Team S.P.I.K.E.293
Unread 06-02-2004, 19:34
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: ADXRS150/300 Sensor
Here are the connections for the ADXRS150EB. I don't know if the 300 is the same.
1) Connect +5V to pin 1 (AVCC)
2) Connect signal to pin 2 (RATEOUT)
3) Connect ground to pin 8 (AGND)
4) Connect +5 to pin 13 (PDD)
5) Connect ground to pin 12 (PGND)
The connections in step 4 and 5 can be jumped from the solder points in steps 1 and 3. I used a prototyping board from Radio Shack that fits a 20 pin socket with 3 holes connected to each pin. It fits nicely in one of the smaller plastic project boxes to protect it.
If you look at the gyro board there is one cap missing. Hold it so that the empy space is at the lower right-hand edge. In this orientation, pin 1 is at the lower left-hand edge. The pins are numbered in order counter-clockwise from there. There is a data sheet for the part at analogdevices.com
Unread 06-02-2004, 22:37
JRHaddock JRHaddock is offline
AKA: Joey Haddock
FRC #3025 (DARC)
JRHaddock is an unknown quantity at this point
http://www.analog.com/
This is the url to the Analog Devices site. Search on ADXRS300 will take you to the product page. Amazing stuff.
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
Reflective tape sensor? scitobor 617 Electrical 2 19-11-2003 08:51
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
