Go to Post Solutions are more likely to be implemented if you provide the solution along with the concern! - Jessica Boucher [more]
Unread 05-02-2004, 21:39
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 639 Vertical Adjustment Rover
Unread 05-02-2004, 21:41
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: pic: 639 Vertical Adjustment Rover
Well, I really wished this could've been possible. In fact, I think Patrick [Dingle] wished it a lot more since he put off his Robocup work for many hours working on this. Using common sense, I thought such a design would be allowed since it is light and wouldn't damage a steel bar. Ah well. Any comments?
[edit] Lol, just saw that the CD-47 bot has quite a few posts and a more than decent # of rep points. [/edit]
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 05-02-2004, 22:52
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
yeah it would have been awesome, too bad though you cant shimmy up the bar. I think alot of us would have liked to.
but that thing is awesome, you should build one any ways to do somthing else like climb a rope or somthing.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 06-02-2004, 01:26
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
That would just be really cool, the hardest part though would be to get it to actually lift a 130 pounds. My first guess would be that the wheels would slip, any idea on how to keep that from happening? Good job! It's a shame you can't use it though
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 06-02-2004, 01:52
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I assume this is just a delivery device.
This thing drops the hook off on the bar... then the robot reels the hook in.
It's very cool... something I didn't think about.
A tether-bot to deliver a hanging hook.
Too bad it's illegal... maybe some other year.
JVN
Unread 06-02-2004, 07:10
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
That definatly would have been neat to see though. Plus, it remminds me of one of the robots from the robot competion that the Techno Channel, during the rope climbing part, the winner was a robot similar to that design who just shimmied (VERY FAST) up the rope with a spring tensioner on one side and the whewl on the other to drive it up the rope just thiw one is all wheel. Good stuff though, hope you guys have been able to come up with anohter idea.
Unread 06-02-2004, 12:02
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
No, as John said, the VAR is used to deliver a hook to the chin up bar. It then detaches (hangs from the cable connected to the hook)... then the robot winches itself up from the side of the platform. The only load on the vertical bar during this process would be from that tiny device.
Yeah, I will see if I can build it anyway with Patrick. Just too cool to pass up
Unread 06-02-2004, 15:30
#1011 (CRUSH)
EVEN COOLER
Unread 06-02-2004, 22:37
Elgin Clock's Avatar
FRC #0237 (Black Magic)
It technically is legal, just not in the way you are thinking.
That's all I am saying, think outside the box.
You'll see what I mean soon enough!
Unread 06-02-2004, 22:45
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Er... I suggest you run all VAR-like designs through FIRST before construction. I don't think they want anyone remotely messing with the vertical bar.
Q: <T04>: Robots can't attach to the vertical bars - this would cause damage with a 130lb bot. However, is it ok to use a rover/tether device 5-10lbs in weight to climb up the pole, attach a hook, and then detach from the pole?
A: No.
Unread 06-02-2004, 22:51
And like I said, "Think outside the box."
It can be done with no rules being broken or even bent, just think about it for a minute or two, and you may be able to see what i am talking about!
V = no
H = yes
Unread 06-02-2004, 23:06
Aaron Knight's Avatar
Aaron Knight Aaron Knight is offline
McWebmaster du Pi
None #0891 (Neverending Chaos...)
Aaron Knight has a spectacular aura aboutAaron Knight has a spectacular aura about
Send a message via AIM to Aaron Knight
V = no
H = yes
Coulda misinterpreted it, but isn't the point of the design to be vertical? You can't touch the vertical bar......
If you're implying attachment to the horizontal bar from the side of it....maybe, but that sounds kinda unlikely to me. You'd have a hard time getting the leverage.
Aaron Knight
Mentor, Team 891: Neverending Chaos...
Behold the Power of PI
Syracuse, NY
email: acknight@syr.edu
aim: akacomputerboy, farktal891
http://www.neverendingchaos.com
DOX, The Un-official FIRST Frat
Unread 07-02-2004, 00:16
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
What he is talking about is an idea that we passed on during brainstorming. That device would be used on the horizontal bar to allow your robot to move side to side as it is hanging, perhaps to block your opponent from latching onto the bar.
Zan Hecht
Unread 07-02-2004, 00:19
Wow you guys are good!! A few people caught my misinterpretation of the wording. Sorry, I didn't realize it was called a VAR - just the concept I was referring to!
Yes, what I am talking about is what ahecht is describing! Thank you for clearing it up for me!
Unread 09-02-2004, 22:54
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Yan deserves an awful lot of credit for coming up with this idea, it's definately one of the original ideas I've seen in some time. Upon one of my weekly visits to the high school to see the progress of the robot, Yan showed me a sketch of this idea. Some of my original questions were:
"Is that legal?"
"How is that supposed to lift 130 lbs???"
Anyway, after at least a half hour of pressing the idea on me (it took me about this long for me to understand the principle concept involved), he finally convinced me that it would work, and then shortly after that I became convinced it would have been the coolest mechanism I've ever seen on a FIRST robot. So I helped him work on the design, pointed out that you need omniwheels in order to make it work, and another college member of the team pointed out that you can make it work spring-loaded, without need for a third actuator. So we drew up this model... Unfortunately, it is illegal The only problem I can see with it is that there is a slot milled out of the vertical bars allowing the horizontal bar to move up and down in between matches, which may screw up the omniwheels in this device, but I'm sure that they could be optimized to work even given the slot.
I think it would be really sweet to make one of these devices that is battery powered (4 Lithium-Polymer batteries would work well and is the size of a cell phone), and controlled using radio.
Anyway, awesome idea Yan. I'm definately available to help work on it for kicks and giggles it if you'd like to. Not sure where I'll find the time......... But..... Too cool to pass up.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
pic: Team 639 Front Omniwheel CD47-Bot Robot Showcase 16 19-05-2004 23:02
pic: Team 639 Robot Before Ship CD47-Bot Robot Showcase 11 31-03-2003 21:35
pic: 2002 Team 639 Final Push Semifinals CD47-Bot Extra Discussion 2 31-03-2003 14:05
