Go to Post FIRST should come with a warning label. - Tim Sharp [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 06-02-2004, 22:16
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
CD Feed
I was looking through the php script found in the nrg.chaosnet.org repository and was trying to figure out how to access the thread id value so that i could create a link to that specific thread using the url chiefdelphi.com/forums/showthread.php?t=[the desired thread #]. Is this possible? or is there some other way of doing it?
Unread 06-02-2004, 22:23
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Re: CD Feed
You would have to use an RSS parser I think...
I have one made up that's going on our new site...if anyone would like, I can post it in the White Papers.
It's really just a modded version of what Brandon had up here before i beileve...I'd have to look again.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 06-02-2004, 22:58
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: CD Feed
You want the threadid via the XML? .. or you want to get it just by browsing?
Brandon Martus
e-mail
Unread 07-02-2004, 02:14
Guest
Posts: n/a
Re: CD Feed
Here's some new code that links to the correct CD thread.
Unfortunately, the external.xml that CD provides only gives the thread's author, not the post's author. I hope this changed soon
You can see the following code in action at: http://nrg.chaosnet.org/resource/pro...eed/cdfeed.php
The code is also stored in the repository, as usual...
PHP Code:
<?php
// If you want to use this PHP code, provide credit to [removed]
$cdfeed "[url="http://www.chiefdelphi.com/forums/external.php?type=XML"]http://www.chiefdelphi.com/forums/external.php?type=XML[/url]";
$fp fopen($cdfeed"r") or die("<b>Unable read ChiefDelphi feed!</b>\n");
while(!
feof($fp))
$xmld $xmld.fgets($fp1024);
$open_stack = array();
$atts_stack = array();
$parser xml_parser_create();
xml_set_element_handler($parser"start_handler""end_handler");
xml_set_character_data_handler($parser"character_handler");
xml_parser_set_option($parserXML_OPTION_CASE_FOLDING,0);
xml_parse($parser$xmld);
xml_parser_free($parser);
function
start_handler($p$name$atts
    global
$open_stack
        global
$atts_stack
    global
$cdthreads;
$open_stack[] = array($name,"",$atts);
        if (
$name == "thread"){
$cdthreads[]=array("id"=>$atts['id'],"title"=>"","auth"=>"","time"=>0,"date"=>0);
$id=$atts['id'];
               print
"<a href=\"<A href="http://www.chiefdelphi.com/forums/showthread.php?t=$id\">n">http://www.chiefdelphi.com/forums/showthread.php?t=$id\">\n";
function
character_handler($p$txt
    global
$open_stack
$cur_index count($open_stack)-1
$open_stack[$cur_index][1].=$txt
function
end_handler($p$name
    global
$open_stack
$el array_pop($open_stack);
        if (
$name == "thread"){
               print
"</a>\n"
    if (
$name == "title"
        echo
"<b>$el[1]</b><br>"
$cdthreads[count($cdthreads)-1]['title']=$el[1];
    if (
$name == "author"
        echo
"By <i>$el[1]</i>"
$cdthreads[count($cdthreads)-1]['auth']=$el[1];
    if (
$name == "date"
        echo
"On $el[1],"
$cdthreads[count($cdthreads)-1]['date']=$el[1];
    if (
$name == "time"
        echo
" at $el[1]<p>"
$cdthreads[count($cdthreads)-1]['time']=$el[1];
// At this point, all the threads have been printed out if PRINTOUT equaled one
// Also all the threads are stored in $cdthreads associative array.
Unread 07-02-2004, 08:35
Robby's Avatar
AKA: Kevin Beranek
Re: CD Feed
Thank you, this is pretty much what I was looking for.
PHP Code:
<?php
while(!
feof($fp))
function
    global
$open_stack
        global
$atts_stack
    global
$cdthreads;
        if (
$name == "thread"){
$id=$atts['id'];
               print
function
    global
$open_stack
function
end_handler($p$name
    global
$open_stack
        if (
$name == "thread"){
               print
"</a>\n"
    if (
$name == "title"
        echo
"<b>$el[1]</b><br>"
    if (
$name == "author"
        echo
"By <i>$el[1]</i>"
    if (
$name == "date"
        echo
"On $el[1],"
    if (
$name == "time"
        echo
" at $el[1]<p>"
Autonomous workking differently tethered in pits, than from feed during competition. Elgin Clock Programming 12 24-03-2003 17:00
NASA Feed on Charter Cable TV dhendrix General Forum 9 24-03-2003 09:12
Transponder info for live feed... archiver 2000 1 23-06-2002 22:14
NASA-TV Feed URL anyone? archiver 2001 3 23-06-2002 22:10
Opinions of teh TV feed Wetzel Chit-Chat 4 29-04-2002 00:46
