Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Unread 07-02-2004, 15:43
wasabi824 wasabi824 is offline
Jason. Another FIRST dude
#0824 (SWAT Robotics)
wasabi824 is on a distinguished road
Send a message via AIM to wasabi824
C programming problem...
hey we're trying to use a simple cosine function call in our code, and we've done the "#include <math.h>" already but we keep getting an error of
"Error - could not find definition of symbol 'cos' in file 'C:\Program Files\MPLAB IDE\default\user_routines.o'. "
when we try to compile. obviously, this is using the MPLAB IDE v6.30... has anyone else successfully used the math functions in their code, or any suggestions on how to fix this?
thanks in advance,
jason
"I am a boring person" - myself
"I am on Team 824" - myself
nope, i don't got any famous people quotes or love haikus or stuff like that.
Unread 07-02-2004, 15:45
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: C programming problem...
Where did you get this math.h library? Unless it was specifically written to adhere to the C18 standard, it won't work.
Unread 07-02-2004, 15:52
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
You could try making a table lookup. Basically make a table in Excel then copy it into your code. the problem with this is you only have the values you put in the table.
rom float costable[numvalues] = {1, .985, etc., etc, etc...}
Check out this thread: math.h
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
we thought that math.h was part of the default C programming library... but any advice on how to implement/call cosine in MPLAB assuming we can't use math.h?
thanks
Unread 07-02-2004, 23:43
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Nope ... there is no sine or cosine for the PIC. The best bet is to make a lookup table and just reference it. I would avoid using floating point variables though and stick to integers. Search CD for "lookup table" and you should be able to find what you need to know. This has been discussed several times.
Unread 08-02-2004, 01:04
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
And, if you do use floating point, use doubles not floats. I had a lot of troubles with roundoff errors until I switched. 100/25 = 3.99 apparently Must be Pentium-based...
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
The problem with scouting... archiver 2001 10 23-06-2002 23:49
control system programming archiver 2000 17 23-06-2002 22:14
programming problem gthakore Programming 16 20-04-2002 12:21
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
