Operator Interface code
I'm having some difficulties getting started with the operator interface (my first experience with programming robot was the EDU code).
Question 1: Is there seperate default code for the operator interface, and if so, where? Question 2: Is there a tutorial/documentation on programming the operator interface. Question 3: How do you load code onto the Operator interface, because it doesn't have the program button like the robot controller. Thanks in advance for the reply. I know I posted in the Control System forum as well, but I'm not really sure where this is supposed to go. |
Re: Operator Interface code
The answer for all questions is the same. The operator interface is not programmable.
The operator interface is almost a "dumb" device. It simply serves as a means by which to get data between the user and the robot. It also outputs a little data (the led's and the numeric display), but all of that is controlled in the robot code.
Bill |
I'm a little confused in this matter, too. In the Competion Port doc, it says something about BASIC and the OI.
Can anyone clarify? |
look at the date on the guide January 13 2003 it's last years operator interfacecompetition port guide
Thanks, I didn't notice.
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| Interrupt timer, executing code asap? | SeanCassidy | Programming | 10 | 07-03-2004 01:47 |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
| InfraRed autonomous code ... | mtrawls | Programming | 1 | 11-01-2004 00:25 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
