Go to Post It's not about the numbers, it's what you can do with them. - AlecMataloni [more]
Unread 05-02-2004, 17:35
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Who needs teasers... here's our arm! [CRUSH: 1011]
Unread 05-02-2004, 17:39
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: pic: Who needs teasers... here's our arm! [CRUSH: 1011]
Nice arm. Now you just need to figure out how to clamp to the ceiling.....or the bar. Good thinking. Keep up the good work.
Unread 06-02-2004, 01:20
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
Thanks, hehe... we just clamped it up there to test it. To all those teams that don't have machine shops... either do we. You CAN build a working arm with sheet metal screws, aluminum tubing, a hacksaw and a drill
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 06-02-2004, 18:30
occra 23.
AKA: ryo
None #1481
umm one word of advice you might find useful. maybe you already have this figured out, maybe you're close on weight but you might want to make your claw's "fingers" wider. like a paddle maybe. definitly easier to grab.
Unread 06-02-2004, 23:42
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Yea.. the arm looks really nice and simple. Thats always good ya know. One question though, how hard are the pinchers holding onto the ball? Like, would you know how many pounds pressure you get on it? It would help... thanx
And an off topic comment:
greencactus3, you ask in your signiture if i can tell you one thing lego cant do.
A planetary gearbox. There are no internal gears. HAHAH!!! got you!
Unread 07-02-2004, 00:13
#1011 (CRUSH)
Actually, we grab the ball great. We have no problem with hanging onto a ball... I gave it a few good tugs and it WASN'T coming out. We are however looking into adding ball guides, we will decide that when weight permits though
Unread 07-02-2004, 06:47
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I really like it - I would just be concerned that another robot could get under it and push it up and out - or does the arm have a really tight grip? We are able to punch ours without it coming off and without the ball even having a chance of popping...
Unread 07-02-2004, 17:22
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
very nice... i like it. as for the grip on the ball... is it sufficient? can the ball be pushed up or down??? an easy solution might be to wrap some rubber hose around your arms to gain some friction...
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
Unread 07-02-2004, 18:22
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
Just an arm? As all of us in OCCRA know, you can build an entire robot with sheet metal, screws, aluminum tubing, a hacksaw, and a drill.
~Aaron
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 09-02-2004, 19:20
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
we did that last year actually...the thign could stack and run aroudn WITH the stack...problem was...we were 30 pounds overweight...so we lsot the whole mechanism...and we ended up being simply a drving box...a then top heavy driving box.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 09-02-2004, 21:37
occra 23.
AKA: ryo
None #1481
no you haven't. too bad...
you know the lego turntable? the small one? it has internal teeth. AND, its a turntable. how easy is it to make a planetary using 1 turnatable, 3 (or 4 or 5) 8 toothed gears. done it before. too bad HAHA!!
no prize for you, but i'll still take challenges.
oh yeah, and mercucio, HOW CAN YOU FORGET THE DUCT TAPE!!?!?!?
for you people who did occra, we're the team that was "beautiful". you know, the dragon....which sucked....need more practice driving maybe..
Unread 09-02-2004, 22:32
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
How are you going to attach the arm to the bot?
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
pic: Team 980's arm hitting the stack at 2 seconds on clock CD47-Bot Robot Showcase 29 01-04-2003 21:48
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
