Go to Post Hey Baker - get a haircut! :) - Sean Schuff [more]
Unread 07-02-2004, 13:40
Dmitri Dmitri is offline
Carthaginian
#1353 (The Gizmos)
Dmitri is an unknown quantity at this point
Question about encoders with detents...
...Digi-Key is out of the detentless Grayhill mechanical encoders that we planned to use for autonomous. Would the detents wear the switch out far too quickly if used on the bot? Does it matter if the encoder also has a switch? Thanks for all your replies.
When in danger or in doubt, run in circles, scream and shout.
Originality is achieved when you stop thinking relative to the box.
Unread 07-02-2004, 20:36
Umm Errr...
Re: Question about encoders with detents...
We also noticed that Digi-Key is out of stock of pretty much any workable encoders. Newark has lots of encoders in stock. Thats where we got ours. Btw i would't use encoders with detents. These are all meant for human interface applications (knobs), and arn't really rated for what you are using them for.
1139 Alumni
Unread 07-02-2004, 22:44
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
If you haven't bought anything yet, check these out. Digi-Key part number 102-1007-ND. The CUI encoders in the upper left-hand part of the catalog part linked below. Kevin Watson (kevin.org/frc has posted an excellent ISR example that makes it very easy to decode the ouput. We got it working and coded in less than 5 minutes.
http://dkc3.digikey.com/PDF/T041/0996.pdf
Unread 07-02-2004, 23:27
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
These are the exact encoders that we (team #538) are using. They seem to be working great so far.
Unread 08-02-2004, 04:21
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Digi-Key has the Grayhill 63R256 in stock. It says it's PC mount, but you can solder wires to it or build a cable for it. Have a look at the attached data sheet for details.
-Kevin
Kevin Watson
http://kevin.org
Unread 08-02-2004, 17:45
Carthaginian
#1353 (The Gizmos)
-Kevin
Thanks for the responses guys but we'll stick to the 288 series, albeit with the Gray code output. We're on a tight budget and can't afford the optical gimmicks. Strange that Digi-Key wouldn't have this popular encoder in stock.
A question about control system options computhief263 Control System 7 04-02-2004 14:46
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
