Go to Post These are threads, and they are what hold the community together...so CD must be a threaded fastener right? - Andrew Blair [more]
Unread 07-02-2004, 22:21
Dave... Dave... is offline
#0005 (Robocards)
Dave... will become famous soon enough
TTL pins
The Edubot had three pins for the TTL port and were labeled as Tx, Rx and BLK. The Fullsize RC has 4 pins and are not labeled other than + and B (the + is +5v).
Does anyone have (confirmed) knowledge of what the B and other middle two unlabeled pins are? Has anyone successfully interfaced with the TTL port on the fullsize RC? I've read some other posts and it seems as though some other teams are having trouble with the TTL port as well.
Thanks, Dave...
"...don't worry about that mechanical problem, Dave can fix it in the programming..."
Unread 07-02-2004, 23:41
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: TTL pins
What we have found (through inspection with a scope) is that from left to right (when looking at the RC in the normal orientation), the pins are +5, Tx, Rx, and Ground.
I don't know if this is considered "confirmed" or not, and we are one of the teams having trouble with that port, but we are currently able to use the TTL port as a TX-only port using that pin configuration... (RX is where we're having trouble)
Unread 07-02-2004, 23:50
#0005 (Robocards)
Re: TTL pins
Thanks Dave!
We're interested in the Rx as well. Hopefully, Innovation First will shed some light on this, even if according to the documentation they "do not support this feature."
I guess I might have to change my signature quote - maybe it can't be fixed in the programming after all!
Unread 07-02-2004, 23:59
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: TTL pins
We too are having trouble receiving. I have been on the phone with IF and they say they will be continuing to research the issue on Monday. I'll post anything I learn.
- Gene Falendysz
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
dowel pins BBFIRSTCHICK Technical Discussion 10 27-01-2003 11:35
how do you hold pins in? archiver 2001 4 23-06-2002 23:45
drill pins Greg Needel Technical Discussion 2 10-02-2002 19:50
