Go to Post Congrats! You are an inspiration to us all! - preussrobotics [more]
Unread 07-02-2004, 20:40
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: pic: Team 30 Dual-Motor Transmission
Originally Posted by RobDeCotiis
sarahb,
dremeling off the gear only poses a threat to the motor of you're lazy. Make sure you don't get shavings inside the motor and i see no reason dremeling the gear off would cause harm. Cutting into the drill motor shaft slightly won't cause problems, unless you hack it to bits. Some people don't have presses, and honestly, you don't need one. The dremel works fine for removing the gear, and simple expansion/contraction properties of the metals will allow you to put the gear on. freeze the motor(or just the shaft, assuming you have liquid nitrogen in your chem lab ) and heat up the gear with a blowtorch and you'll be able to get it on, and when it cools down, good luck getting it off. Try to think a little more about reasoning before you post. You yourself have seen the motor ryan put the gear onto, you know it works fine, the motor isn't damaged, i don't really see what the problem is. anyway. beautiful looking gearbox, ryan. nice job
Team 30 forever
Rob DeCotiis
I'm no electrician here... but I would take a guess and say putting your motor in liquid nitrogen is probably not a very good practice if you want to have a working motor... Taking a blow torch to the gear could also severly weaken it. There is nothing wrong with having concern and giving advice against doing something that you know isn't the correct method doing the job. We are trying to learn about engineering and teaching others in FIRST, not about cobbing up a job that is easily done correctly.
Ryan, could you post up or pm me the gear ratios in there? It appears that you have the bosch motor pulling up atwood above its free speed. (also not a very good thing to do)
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 07-02-2004, 21:02
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
dipping the shaft in liquid nitrogen won't cause any problems to the motor. using a blowtorch on the gear won't either. both of these are common practices in the engineering world. When fittings are needed that are extremely tight, to the extent that the shaft diameter is greater than the hole diameter by very large amounts, these practices are used along with a press fitting. The end result is an EXTREMELY tight interference fitting. If a team doesn't have a press, these practices are accepted in the engineering field, and because, as you say, we should be teaching engineering, i figured i'd throw a little bit more engineering knowledge into the mix, being that nobody's posted that as a way to fit the gear on. again, please look into what you're talking about before making blind assumptions
Unread 07-02-2004, 21:14
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
sarahb,
As Rob said before, using liquid nitrogen on a motor is a really bad idea. It could damage many parts of the motor, including the cracking the cooling fans or the bush assembly. I would listen to him, considering he knows enough to be a technical moderator of these forums.
Yes, I have seen the motors that Ryan modified. All of them have damaged shafts(lots of little cuts), at least one has shavings in it, and two have damaged bush assemblies. All three were replaced, and I believe the gears from the new ones were pressed off the right way.
Once again I will ask all of you to please stop encouraging other teams to damage their motors. If you don't trust my assessment that Dremeling off pinions is bad, please refer to the numerous other posts that agree, especially the ones by Paul Copioli, a well respected professional engineer and Unsung FIRST Hero.
Unread 07-02-2004, 21:32
FRC #1660
How exactly will cooling the motor damage it?
Unread 08-02-2004, 01:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
OMG, don't you all understand that they will not be dipping the whole motor in the LN. All they need to put in is like 1/2" for the shaft, not the whole motor can too. The only part in the LN should be the shaft.
Unread 08-02-2004, 08:39
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Each one of these has a weight of approximately 9 pounds. Fine devices, really.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 08-02-2004, 09:47
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
sarahb,
Actually,
One of the best motor guys on these forums, a professional who does this thing for a living came on here and said NOT to dremel the drill pinion off as you will likely destroy your motor.
RobDeCotiis, please refrain from talking about things which you "know" unless you really know them.
Simply be searching these forums, you can find someone who's opinion really matters.
Team 30--
The gearbox looks good.
Unlike my teammate I won't try to count teeth and check your ratios. I just assume you would have done it right the first time. Good luck, and we'll see you in Long Island.
JVN
Unread 08-02-2004, 11:58
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Cooling the shaft is probably OK. Blowtorching the gear probably is not. You can create huge stresses in the part, and you are chaning the material properties. The sudden change in temperature can be damaging. Parts are usually heted in a controlled process, like an oven that gradually increases the temperature.
Yes, the practice of creating interference fits is common and used in many engineering applications.
It is a very controlled process. Part diameters are defined, analysis is completed. An interference might be thousandths or ten-thousandths. When you create this tight fit, you add new stresses in the mating parts and if the fit is too tight, one or both parts can fail.
Do you know what kind of interference you are making? Did you measure the parts first?
and because, as you say, we should be teaching engineering, i figured i'd throw a little bit more engineering knowledge into the mix, ... again, please look into what you're talking about before making blind assumptions
No further comments.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 08-02-2004, 16:59
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Caution to all reading this thread. Some of the processes expressed by some of the teams are very risky. Please use well thought out processes based upon "best practice" and above all practice safety at all levels.
Also consider advice from the persons that have expertise in the field of question as more reliable but not faliable. All are entitled to their opinion on how to best do something but again excercise caution.
Mike Martus
Unread 09-02-2004, 01:16
We are broaching and milling keyways in all our gears this year to lock them to the shafts. While we have not run it under significant load yet, so far it appears to be functioning extremely well.
Unread 09-02-2004, 08:19
Al Fielder Al Fielder is offline
Engineer / Mentor
#0933 (Trigos)
Al Fielder is on a distinguished road
In another post, I described how to remove the pinion from the Bosch motor. It really wasn't difficult. Taking a Dremel to remove the pinion seems to be alot of work, with risk, when a puller will work just fine. The press fit for a new gear should be in the .0003-.0005 range, specially if you are installing a gear with a P.D. of around .7-.8 so that you don't yield the new gear.
If the new gear yields, you lose the press.
Unread 10-02-2004, 15:01
Dorsk65's Avatar
Dorsk65 Dorsk65 is offline
Robots first,Sleep second
AKA: Robert Bloom
#0833
Team Role: Student
Dorsk65 is an unknown quantity at this point
Well, on a completely different note, well done. This gearbox is vastly smaller and lighter than ours, mainly because our sprockets are 1:1, so we needed extra gears. We used the 20 Pitch gears also, and I hope to post pictures soon. The only problem we are having seems to be heat, so you might want to mount some fans on it.
Once again, very well done, paticularly on the weight and stability.
Robert Bloom
"It won't work." (or something to that effect)
-Our always optimistic leaders
Unread 10-02-2004, 18:35
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Robert Bloom
Thanks for the vote of confidence Robert, I hope to see pictures of your gearbox up here soon. Wish we were having your nice Hawaii weather here in the Northeast.
-Rc
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
