Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 23-02-2002, 14:50
ark_1230's Avatar
ark_1230 ark_1230 is offline
What the Random?
AKA: Andrew
FRC #3138 (Dayton Innovators)
ark_1230 is an unknown quantity at this point
Question Rotating Light
When does the light have to turn on?
Is it when your robot is powered on manually, or when the match starts and you gain control of your robot?
Unread 23-02-2002, 15:21
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
It has to be powered by a spike relay which is kept constantly turned on by your program. (If you're using the default program, it must be attached to relay output 8.) The effect is that the light will come on when your robot is enabled, and go off when it is disabled.
Unread 23-02-2002, 23:13
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Don't make the mistake of programming it so that it takes a switch to come on. They don't like that. It must come on when the robot comes on.
~Adam
Unread 26-02-2002, 03:44
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Am I correct in that if the OI isn't talking to the RI then the light shouldn't be on? In other words, it can't come on until you are given control.
Viva Olancho!
Unread 26-02-2002, 05:23
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
You're sort of right in that the light doesn't come on until you are given control. However the OI and RC continuously communicate as long as they both have power (assuming they are set up properly with the team number and channel, etc.) The user program you downloaded to your robot even runs the whole time the robot is disabled. You can verify this (assuming you have a yellow dongle (tm) with which you can disable your robot) by putting debug statements in your code. You can see that the RC receives all the inputs from the OI and the analog and digital inputs on the robot. What happens when the robot is enabled, and you gain control is that the data your user program sends in the serout command actually get acted upon. (They are ignored by the master microprocessor as long as the robot is disabled.)
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
rotating light archiver 2000 1 23-06-2002 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
